Results 1 to 5 of 5
Thread: l298 l297 driver 2A with stepper 3A help
    Mar 2007
    tunisia
    i have done my pcb l298 l297 2A
    its work perfect with stepper 1A
    but when i change with 3A stepper i uses 0.666 vref at paralell 2.1
    with pc power supply 12v
    but l298 heat abnormal more then 120 degre c
    i put aluminuim and 3 fan cooler but chip very heat
    did some 1 have solution haw i do
    thanks
    stepper =
    Typ : bipolar / (unipolar)
    Strom : 2,2 A (3,0 A) / Phase
    Haltemoment : 1,65 Nm (1,3 Nm)
    Widerstand : 0,9 Ohm / Phase
    Induktivität : 2,2 mH / Phase
    Attached Images Attached Images
    Attached Files Attached Files
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    The L298 is rated a maximum of 4A ehn both channels are paralleled. Typical stepper configuration is 2A max.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
    Mar 2007
    tunisia
    What's your main
    did this work ?
    Mar 2005
    ASIAN
    yes, u can use 2A driver with 3A motor, but it is lower torque
    Jun 2003
    St. Peters, Mo USA
    Yes you can run a motor at less than it's rated current. The result is lower torque.
    1. Problems with stepper driver (L297 and L6203)
      By MagooT in forum Open Source Controller Boards
      Last Post: 09-07-2012, 07:35 AM
    2. L298, L297 Stepper Driver
      By abbe in forum Open Source Controller Boards
      Last Post: 07-01-2012, 11:25 AM
    3. Problems with l297/l298 based driver
      By Jykke in forum Stepper Motors and Drives
      Last Post: 01-13-2012, 12:44 PM
    4. L298/L297 strange stepper motor noises
      By cnc kiwi in forum Stepper Motors and Drives
      Last Post: 12-26-2007, 11:18 AM
    5. L297-l298 stepper board design
      By watchman in forum Stepper Motors and Drives
      Last Post: 03-29-2007, 10:00 AM
