Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
Old 10-11-2008, 05:00 AM
Alwyn is on a distinguished road
EMC2 HELP HELP HELP
I'm either blind or have some function disabled but how can I position a nc file within the red boundry box of EMC2 so that it does not go past the limits?
Old 10-11-2008, 09:55 AM
acondit's Avatar
acondit is on a distinguished road
This thread should really be in the EMC2 forum. But if your limits are set correctly for you machine, and the item is still outside the boundaries, then the boundaries should tell you which way you need to move the part to be within the boundaries. However, if the part is actually inside the limit boundaries of the machine, you probably just need to touch off on a different edge of the part (i.e., change the offset for the machines x0 and/or y0). There is a touch off button in the Axis gui.
Alan
http://www.alansmachineworks.com
Old 10-11-2008, 12:18 PM
cyclestart is on a distinguished road
This link is a bit old but the info should still be good
http://www.mail-archive.com/emc-user.../msg03400.html
As Alan said, this assumes the machine limits have been setup properly in the .ini file. The machine should be moved to a 'Home' position at start up regardless of whether you use physical home switches.
hth
Anyone who says "It only goes together one way" has no imagination.
Need Help!- M8 still not being red by EMC2 SpeedsCustom LinuxCNC (formerly EMC2) 27 04-13-2008 04:36 PM
EMC2 to diy CNC dakiller322 LinuxCNC (formerly EMC2) 11 10-05-2007 01:16 AM
Emc2 sdantonio Mach Mill 2 02-05-2007 03:26 PM
emc2 -hal*? essa LinuxCNC (formerly EMC2) 3 05-27-2006 01:06 PM
emc2 heilcnc LinuxCNC (formerly EMC2) 2 05-23-2006 06:03 PM
