Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
Old 08-29-2008, 06:03 AM
lleroy is on a distinguished road
ANNOUNCE: pycam - 3D CNC Toolpath Generation‏
Hi folks,
I just released a GPL 3D CNC Toolpath Generation program.
You can see some screenshots of it in action at:
http://sourceforge.net/project/scree...roup_id=237831
You can download it from:
http://sourceforge.net/project/showf...roup_id=237831
The GUI is not very sophisticated yet... and the project website is fairly minimal,
but it should be functional...
Please let me know if you are trying it out and what you think...
I'm especially interested in hearing about someone actually using it
to create physical objects...
The first one to do so can put a picture on the project page :-)
-- lode
Old 11-11-2008, 01:26 PM
lezdep is on a distinguished road
I'm trying your application at the moment. Finishing toolpath looked kind of OK.
I've also got Roughing toolpath from second attempt. I'll have to spend
more time testing it (simulation in EMC2). Major issue I have before I could
run generated toolpaths is 0,0,0 position of the tool at the 0,0,0 coordinates
of the machine. That's deep inside my stock I will have to modify toolpaths
manually for now for testing, but would love to see a way in your app to
specify start location relative to stock for g-code program.
Side question - would you be willing to work together with other toolpath
developers and myself on attempt to integrate algorithms into one CAM
Application ? I can suggest 2 alternatives - new app based on Open
Cascade Application Framework (reviving cam-occ project) or adding
3 axes support to GCAM. Toolpath algorithms would have to be ported
to C/C++ though.
Old 11-11-2008, 11:29 PM
I've just tried to run roughing and finishing toolpaths in EMC2's simulation again.
Actually biggest issue, which would prevent me from running them on real CNC
machine, is the way rapid movements are coded. Many rapid moves are done
alongside the stock with tool partially inside stock. That will brake the tool for sure.
I'm not certain if it is related to 0,0,0 start location, but it seems to me that rapid
moves are done towards the middle line of stock, instead of out of the stock to
safe distance above it. Could you check your logic there ?
I've only tried couple of combinations suggested for roughing and finishing like
"Cylindrical cutter with the PushCutter Pathgenerator and the Polygon PostProcessor" and
"Spherical cutter with the DropCutter Pathgenerator and the ZigZag PostProcessor".
For other combinations I saw toolpaths generated with rapid moves right through the
stock Looks like these rapid movements require lot more work in current version.
Old 11-14-2008, 11:39 AM
new release 0.1.4
A few bugs have been fixed since the 0.1 release...
It should now be able to generate toolpaths for EMC2
Feedback is welcome...
Old 11-16-2008, 11:51 AM
Dan Falck is on a distinguished road
Hi lleroy,
Thank you for producing this program. I think it this program can fill a gap in the opensource CAM world. I was able to run pycam-0.1.3 successfully (on Ubuntu 8.04). When attempting to run pycam-0.1.4, I get this error message:
~/CAM/pycam-0.1.4$ python pycam.py
Traceback (most recent call last):
File "pycam.py", line 6, in
from pycam.Gui.SimpleGui import SimpleGui
File "/home/dan/CAM/pycam-0.1.4/pycam.py", line 6, in
ImportError: No module named Gui.SimpleGui
Old 11-16-2008, 01:56 PM
Hmm, I'm running 0.1.4 on same Ubuntu version just fine. Have you installed all
required dependency packages ?
So far my tests with 0.1.4 produced quite decent results. Beside some limitations
of algorithms, tools to not crash into stock anymore and I plan to do real cuts on
my CNC Mill as soon as I have time. I encourage others to try it and provide feedback.
This way Lode could make it better.
Old 11-16-2008, 02:18 PM
The dependencies shouldn't have given a problem on this system (in theory...) since pycam-0.1.3 works. I use pyopengl and togl for a lot of other projects. But,that's not to say that Togl isn't causing problems this time-or that I don't have file permissions set wrong- or my directory paths wrong...
I'll dig a little more.
Thanks,
Dan
Old 11-16-2008, 02:33 PM
looks like there is a missing file in that release.
you can fix it by copying the file pycam/__init__.py from the 0.1.3 release...
thanks for reporting this!
-- lode
Old 11-16-2008, 02:38 PM
lleroy,
Thanks- that was it.
Dan
Old 11-16-2008, 03:21 PM
lleroy,
Could you introduce a feature to be able to change the direction of the cutter path? I would like to run the cutter from +Y to -Y on some parts.
Thanks,
Dan
  #11   Ban this user!
Old 11-17-2008, 04:03 AM
yes, that's easy... it will be part of the next release... meanwhile,
you can get the current code from subversion:
http://pycam.svn.sourceforge.net/vie...ar.gz?view=tar
-- lode
  #12   Ban this user!
Old 11-17-2008, 09:34 AM
lleroy,
I did a SVN checkout and it works. Thank you- that's it.
Dan
ANNOUNCE: pycam - 3D CNC Toolpath Generation‏ lleroy General CAM Discussion 0 08-29-2008 05:56 AM
Need Help!- NX4 toolpath generation thirumalkumarn General CAM Discussion 0 05-27-2008 08:47 AM
How to generation toolpath ? havythoai Coding 5 03-18-2008 10:47 AM
toolpath generation algorithm for NURBS jbacon General CAM Discussion 3 08-03-2007 09:48 AM
Full 4 axis toolpath generation? Konstantin Rhino 3D 5 11-12-2006 01:14 PM
