| OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc) |
#13
Anywho ... ![]() Spiro was a one man project, but spalm still left it open for anyone to add to. Which is a good start for a larger project.. |
#14
| Initially I was, but after it became apparent that this forum had typically not gotten past the idea stages, I branched out and started proposing my own ideas... I'll admit I'm a sorry programmer too, but I still think it would be neat to use OpenCacsade as the basis for a powerful opensource application supporting both CAD & CAM... Dan, what "studying projects" were you reading about it? I'd like to see those... |
#15
| Here are a few Opencascade projects that I know of: http://sourceforge.net/search/?type_...ds=opencascade http://lignumcad.sourceforge.net/doc/en/HTML/index.html http://cam.occ.googlepages.com/home Dan |
#16
| Dan- Thanks for the links. I've seen Cam.Occ, and I'll look into the other two... Really obvious question (doing 3 things at once, so I'll ask it just in case someone answers before I have time to find it...) : Is OpenCascade written with the intention of being run in Linux, or something else? The reason I ask, if it were then that fact would greatly enhance the option of perhaps coupling it with EMC... |
#18
| "Really obvious question (doing 3 things at once, so I'll ask it just in case someone answers before I have time to find it...) : Is OpenCascade written with the intention of being run in Linux, or something else? The reason I ask, if it were then that fact would greatly enhance the option of perhaps coupling it with EMC..." Opencascade is open source and is currently set up for Windows and Linux. I run it under Ubuntu Linux. Dan |
#20
| I'm running and studying Opencascade, mainly to see how it's done. I am just a novice at it. The guys who are writing the software in the links that I put up earlier can tell you a whole lot more about it than I can. I am playing around with python programming and have found that I can write little scripts that can control larger programs in C. I have also taken other people's python programs, modified them and learned enough to be dangerous ![]() If you want to check out a simple, but easy to understand python CAD type application, check this out: http://members.localnet.com/~blanding/cadvas/ Doug made it really easy to understand how a CAD program can be written. I have been hacking it to extract entity data, in the hope to use it for CAM. I'm starting to make progress. Dan |
#21
| Hi, I'm the guy writing cam-occ. I wouldn't call the code clunky. It was good enough that Dassault bought all rights to their then-current version of Euclid, as well as Strim. Matra retained rights to all previous versions of Euclid, and then released this code as OpenCAS.CADE. Some of it is documented in French, so the code itself isn't alwasy easy to read - but they provide quite a bit of documentation in the form of pdfs and doxygen html. It has a fairly steep learning curve which is offset by the demo programs they provide. (Alas, I have not figured out how to build them on x86-64 linux)
![]() OCC does contain one demo of interactive 2d drawing, using Draw Harness. It's contained in CASROOT/ros/src/DrawResources/PROFIL.tcl . It's broken in occ6.1. If you want to try it, start DRAWEXE. Type in pload ALL and then source PROFIL.tcl
![]() Mark |
