Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
  #13   Ban this user!
Old 11-09-2005, 12:21 PM
John_PE is on a distinguished road
Originally Posted by anoel
...Also there was a really cool demo at the PDC show where there was a company that was doing "Realtime" OS with windows by running WindowsCE underneath Windows XP and the software was marshalling commands from XP to CE which in turn commanded a really cool milling robotic arm in realtime.
The robot controller was actually running Windows XP along with the VxWorks RTOS. There was a computer sitting next to the robot controller running MasterCAM piping the path data over a NULL modem connection. The robot was a 250KG model manipulating a router spindle type end-effector. You can read more about the control software at www.kuka-controls.com
/ Disclaimer - I do work for KUKA Robotics and was the engineer supporting the PDC display.
  #14   Ban this user!
Old 11-09-2005, 12:33 PM
Originally Posted by GregMM
Hey switcher, I do have a site, however there isnt anything there right now, the first couple betas will probly just be posted here, but it will probly be a little bit before its ready for a beta, im actually taking a robotics course in college right now, and I am experimenting with a more universal approach to the program, rather then making it 3 axis/4 axis/etc, im going to try and make it support unlimited axes using a machine configuration file which will be able to hold wither the Denavit-Hartenburg Notation paramaters for generating the coordinate frame transformation matrix, or the transformation matrix itself, but using these matricies, I should be able to generate a jacobian matrix to do inverse kinimatics (figuring out how much to move along the axis in the axis's coordinate plane, in order to get tot the point in the base frame, or real world coordinates) should make things pretty interesting and should only need three types of joints, prismatic (linear actuator type joints, like normal X, Y, Z axes), revolute (rotational axes, like a fourth/fifth/etc axis), and a special case of the revolute joint that will rotate based on time like the rotating part of a lathe, although the last is actually only used in simulation), I also want the machine description to include 3d parts for the simulation, as it would look cool to have a good looking solid simulation with the machine and all, instead of just the toolpath
Good luck with your project. Don't spend too much time deriving a completely general kinematics model - just cover the basic machine configurations. Also don't forget about joint singularities where applicable.
Windows is notoriously inconsistent for motion control applications. I would not recommend attempting to update motor positions/velocities with a period less then 50 milliseconds.
  #15   Ban this user!
Old 01-02-2006, 09:21 PM
GregMM is on a distinguished road
ok still working on it, got a little side tracked with all the .net 2.0 stuff, but its looking pretty good, converted all collections to generics which sped up the code a lot, worked a little bit on solid generation (although its still pretty crappy right now, its really just a surface the moves to lowest z on the tool path, im going to be taking a simulation course this semester so hopefully ill be able to get some sort of actual solids going, if anyone knows of a good tutoiral on solids from a programming perspective, it would be cool if you could post the links here) worked on the interface a little bit, .net 2.0's toolbars are soo much better then the originals, changed to only supporting 6 axes instead of a variable number for speed reasons and also GCode only supports 6 axes XYZABC, plus im sure most of the machines here arent running more then 6 axes heh, well heres a screenshot of what it looks like so far
  #16   Ban this user!
Old 01-06-2006, 12:40 PM
turmite is on a distinguished road
Greg,
I need a little clarification. Is this a cam program or a motion control i.e., mach2/3/4? I first though you were doing a cam program but it seems now it is a motion controller. ?? Edited to add Duhhhhhh! I just went back and re-read your original post! Sorry.
John_PE,
Do I understand correctly that the program will control a robot like we see doing welding and things? Does it use gcodes, output signals for the motors?
More info please,such as, is the program available, now and how expensive or affordable?
Mike
No greater love can a man have than this, that he give his life for a friend.
  #17   Ban this user!
Old 03-10-2006, 06:47 PM
Just wanted to say that this project is not dead, its been put on hold for a while, Im taking a game programming class in college so most of my time lately has been working on that, probly going to order some motor controllers soon, so ill be able to actually test movement (atleast as rotation is concerned, dont know when im going to get around to building the actual machine, hopefully not too long after the semesters over though)
  #18   Ban this user!
Old 07-31-2006, 06:22 PM
GisMo is on a distinguished road
GregMM,
I am VERY interesting in your project. What's the status? If your interested, I've got tons of suggestions.
GisMo
  #19   Ban this user!
Old 03-18-2009, 03:08 PM
rozanc is on a distinguished road
very nice I can't wait to see the code
  #20   Ban this user!
Old 09-05-2011, 10:15 AM
PatrickKeenan is on a distinguished road
Hi GregMM,
I am working on a similar project, are you still working on this one? (last post is from 2009) I have come to the realization that what a lot of people say about the CLR and .Net is true: .Net is not ideally suited to real-time. After buying a dual parallel port card and spending a week nailing down parallel port control on my system (Windows 7 OS, 64bit) by altering the code from Levent Saltuklaroglu (see I/O Ports Uncensored - 1 - Controlling LEDs (Light Emiting Diodes) with Parallel Port - CodeProject) to talk to my motor driver (SOC Robotics MK5 5-axis) and finding the drivers and .dll that will work on 64 bit (if anyone wants this send me a message), I have run into the following problem: I cannot change messages to the port in less than a millisecond. If I want to pulse a step pin high I either need to Thread.Sleep(1 ms minimum) or spin for a machine dependent amount of time and completely tie up a processor before I make it low again and after that I need to wait at least another millisecond before I step again. This is resulting in slow rpms. The manual for the MK5 says I only need to hold the step pulse high for at least 10 micro seconds.
this is not a downer post however, I plan to use a work-around. Page 12 of "Threading in C#" by Joseph Albahari has some very interesting things to say about real time but even he says "Even with an elevated process priority, there’s a limit to the suitability of the managed environment in handling hard
real-time requirements. In addition to the issues of latency introduced by automatic garbage collection, the operating
system may present additional challenges—even for unmanaged applications—that are best solved with dedicated
hardware or a specialized real-time platform." Taking this advice I plan to go the dedicated hardware route. I have an Arduino Mega sitting around that seems perfectly suited to this. The mega has time granularity down to micro seconds (Arduino - Micros) and since I wont be driving anything besides logic it should be really stable. Besides, it will make a nice open-source statement and look cool stacked on top of the green MK5. My rough strategy is this: I will create a vector (x1(t), x2(t), x3(t), x4(t), x5(t)) on the pc with t = startTicks - Now.Ticks (System clock and Now.Ticks has granularity down to one hundred nanosecond intervals), I will send messages to the microcontroller telling it these goal positions, If the actual position is farther away from the goal than it was in the previous cycle then it will speed up, if its closer it will slow down, when a limit switch is closed for a given axis its position will be reset to 0 or max to account for miss-steps...
I plan to use Math.Net to handle the symbolics, derivatives, and interpolations.
I have not looked at the graphics part yet but what you have looks really good. I would be very interested to see the code that produced those renders. Any advise out there from people dealing with similar obstacles would be very appreciated.
_PK
