Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > OpenSource Software
OpenSource Software For the Discussion of Opensource CAD/CAM and NC shareware software etc)
  #61   Ban this user!
Old 08-29-2005, 03:38 AM
tastefulasever is on a distinguished road
Death Adder,
You are right that Blender's user interface is definitely not beginner friendly. But once the learning curve is over, modeling becomes very quick. Also, the proposed CAD interface could be much more intuitive, and is probably the way most CNC operators would use the program.
Blender has built in support for animation, using either paths, keyframes, or motion curves. This should be more than adeqaute for cutting simulations, no matter how many axes are involved.
For example, the cutters path would naturally be guided by path animation, and cutter tilt or lathe rotation would be handled by motion curves.
I don't think that the simulation will be slow, because Blender is known for being one of the fastest pro 3d animation programs. Faster and lighter (less than 5mb download) than Maya, 3DSMax or Lightwave, which are some of the most popular proprietary animation softwares.
I think that Blender would be faster than MasterCAM, which is the only pro CAM software that I've had any experience with.
Blender doesn't need to have CAM scripts, as any CAD work could be exported, but that isn't very convenient. The cool thing with scripts is that you can run them one at a time, so you never have too much resources dedicated at once.
Anyways, I'll upload the CAD interface when I finish a few basic functions, so anyone who uses Blender can try it out.
In any case, there is a real need for a comprehensive opensource CAD/CAM solution.
Peace.
  #62   Ban this user!
Old 10-08-2005, 04:05 AM
Much later than anticipated, I have made some progress on the CAD interface script for use in Blender. However it is still far from complete.
The script can be downloaded here: http://branerd.net/pycadblend.txt
You will probably have to change the file extension from .txt to .py
And a Blender forum thread I started for the script is here: http://www.elysiun.com/forum/viewtopic.php?t=51114
The thread covers what works at this point.
You can download the latest version of Blender here:
http://blender.org/cms/Blender.31.0.html
Be aware that there is a learning curve when learning any advanced 3d application, and Blender is not an exception.
