Results 1 to 3 of 3
Thread: Gcode to DXF and working time forecast
    May 2007
    Italy
    Hi all. I have just released an updated version of NCCL that includes some bug fixing and a new small application entirely written in this language. It does have a user interface written in AutoiT that helps creating the script that is then executed.
    The application does two things :
    1) Convert one or more files from stanrdard ISO code to DXF
    2) Create a report with some basic information about the processed file including a forecast about the time it will (should) take to machine the workpiece.
    If someone want to try it and compare with the true machining times, I woukd like to know how accurate is the calculation. It only works with 3 Axis cnc code. 5 Axis is not supported (may be in the future..)
    If you want to give it a try just go here : Main Page
    Many thanks
    Sandro
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    I like my GCode to DXF program better
    Wayne Hill
    May 2007
    Italy
    I agree Wayne ! I think your program is definetely better than mine :-)
    Sandro
  1. working time calculator
    By oneeye in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-14-2010, 06:43 AM
  2. Need Help!- long time reader first time poster
    By blu333 in forum General Metalwork Discussion
    Last Post: 02-21-2010, 06:30 AM
  3. Working time calculation
    By Ideas L in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 11-09-2007, 07:13 AM
  4. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-02-2007, 07:18 PM
  5. Replies: 0
    Last Post: 03-10-2005, 01:46 PM
