Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Opensource Forum Rules
Old 05-07-2008, 06:28 PM
dnaworks is on a distinguished road
Industrial parts supply source for Canadians?
Hi all,
Pleasure to meet y'all! I'm trying to build a CNC machine based on the great instructions from Stuart MacFarlan @ Instructables. I'm proceeding along nicely but I'm stuck at one particular point now.
I attempted to ordere parts from McMaster-Carr for my CNC project and appeared to be able to do so fine - the web page took my credit card, sent me a confirmation email, yadda yadda yadda. However, about two hours later, I received what was essentially a PFO letter from McMaster-Carr stating that due to "increasingly stringent export legislation" that they were canceling my order. This frustrated me, of course, but what's worse is I have no idea where to find a different vendor.
The parts of interest are listed below but I don't have enough experience to figure out what alternate names are, or what these are actually called, so that I can search somewhere else. If anyone in Canada (Calgary, perhaps?) has a suggested industrial supplier, or a US one that exports, please, PLEASE let me know.
  • Binding Screws for Wood Plain Steel Dowel Nut, 1/4"-20 X 12mm Length, Packs of 50
  • Steel Ball Bearing Plain Open for 1/4" Shaft Dia, 7/8" OD, 1/4" W
  • Trapezoidal Tooth Neoprene Rubber Belting .080" Pitch, Mxl Trade Size, 1/4" Width
  • Mxl and XL Series Timing-Belt Pulley 1/4" Belt Width, .685" OD, 20 Teeth
For example, any searches on the "rubber belting" give me nothing but automotive timing belts. Any help would be greatly appreciated!
Thank you,
Donald Wheeler
Last edited by dnaworks; 05-07-2008 at 11:10 PM. Reason: spelling mistakes ... grrr
Old 05-07-2008, 07:40 PM
Al_The_Man's Avatar
GoodYear have a line of timing belts aimed at CNC type applications, also Breco Belt.
But You may want to order a Misumi Catalogue, mine arrived by purolator next day, treasure trove of hardware.
Old 05-08-2008, 10:34 AM
tulsah is on a distinguished road
I'll concur that Misumi is a great source. Another alternative for the belts and bearings would be Motion Canada.
Old 05-08-2008, 10:51 AM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
http://www.acklandsgrainger.com/AGIP...do?language=en
belts and miscellaneous stuff
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 05-08-2008, 08:47 PM
Al_The_Man's Avatar
...Also Reid Supply has a good catalogue and for local service, In Calgary, I would expect that either Bearing & Transmission, Bearing Supply or B.C. Bearing have a presence, they can get almost all you need also.
Old 05-19-2008, 11:34 AM
ged ged is offline
ged is on a distinguished road
Try "Rubberline".They manufacture belts and hoses and the have outlet stores that sell to the public.I had them make 5/8 x 1/8 kevlar flat belts for me at a cost of 5 bucks ea. Im sure the would have timing belts in stock.
Old 05-20-2008, 12:05 PM
DareBee's Avatar
Monkeywrench Technician
DareBee is on a distinguished road
Those aren't conveyor belts, they are standard timing belts. Any bearing and power train supplier should either have stock or be able to get those in less than a day.
For example - I would buy the binding screws at Fastenal and the other items at SB Simpson.
I do, however, buy most of my conveyor belting from Rubberline.
www.integratedmechanical.ca
Old 03-28-2009, 12:19 AM
lex69 is on a distinguished road
rubberline is a great source but check falcon products also.. They are a little cheaper.
Old 03-29-2009, 12:09 AM
Schweinhund227's Avatar
Schweinhund227 is on a distinguished road
Smile
There I was..... Thinking I was Alone to have been TURNED DOWN by McMaster-Carr
Hope you can Complete the Project.... I am working on the same instructables CNC But having Faced McMaster-Carr Reject Email ! Blah blah......
I had to improvise fast !!! I plugged most of the Holes that were going to be either... Timing Belt Roller and Bearing holders... and Redesigned the Support Gantry to be Driven by Lead Screws ! and Coupled to a Moving Knot Jig and Elevated the Y Rails by 1" to Enable me to Feed pieces under the Y axis... Which you could only do with the X Axis
Best of luck with yours....
It's well underway !!! and I can't wait to start using her...
Maybe Try Princess Auto for most hardware... if you have one near by? Lead Screws, Bearings, 1/2" Rods and Mill heads and I saw Timing Gears in the Surplus Aisles.
Norm
Kingston. ON
Old 07-19-2010, 03:40 PM
brunog is on a distinguished road
Norm
Kingston. ON
Some industrial supply vendors in Canada can get you products from McMaster-Carr at the same price within a perhaps longer leadtime in some cases. Lafco www.lafco.ca is on of them. Lafco has stores in Montreal QC, Quebec city QC and St-Catharines ON
Best regards
Bruno
Montreal,QC
Old 07-19-2010, 05:16 PM
Al_The_Man's Avatar
BTW, Misumi now offer duty free/brokerage-included shipments to Canadian customers.
  #12   Ban this user!
Old 07-11-2011, 02:55 AM
AssassinXCV is on a distinguished road
Fastenal has many industrial parts ranging from
Fasteners
Tools & Equipment
Safety
Material Handling & Packaging
Chemicals & Paints
Cutting Tools & Metalworking
Electrical
Abrasives
Janitorial
Lifting & Rigging
Plumbing
Hydraulics & Pneumatics
Power Transmission & Motors
Welding
Metals & Fabrication
All Fleet & Automotive
HVAC
Mil-Spec
Office Supplies
They can lack of stock majorly in my area, practically EVERYTHING would have to be shipped in. And their prices can be pretty steep at times.
A machine is only as accurate as the tools used to build it. "CNC = Computer Numeric Control - or on some days - CNC = Can Not Control" Imagineering
Tags
canada, cnc, hobby, parts
Parts source for 9X20 - got one? mxtras Mini Lathe 20 11-03-2011 04:18 PM
Can anyone help with a parts source? PoppaBear10 Bridgeport and Hardinge Mills 11 08-18-2006 06:26 PM
Traco TSL480 48V Industrial DC Power Supply 10A ullbergm General Electronics Discussion 33 03-06-2004 08:13 AM
48V Power Supply Source ?? ninewgt General Electronics Discussion 7 06-25-2003 11:10 PM
