G-Code to DXF - Page 12
Page 12 of 12 FirstFirst ... 29101112
Results 221 to 229 of 229
Thread: G-Code to DXF
  1. #221
    Member WayneHill's Avatar
    Mar 2004
    Michigan
    There are contributes on this thread there that are taking this project to a higher level. My participation on this conversion development has ended. Onward to other projects.
    Thank you,
    Wayne
    Wayne Hill
  2. #222
    Member scorch's Avatar
    Dec 2010
    Default G-Code Ripper Now Exports to DXF
    I have updated G-Code Ripper to export DXF formatted files. The latest G-Code Ripper files are located here G-Code Ripper V0.05.
    The rapid and controlled moves are written to different layers with different color indexes. The rapid moves can optionally be omitted from the G-Code Ripper output.
    All of the arcs (G2/G3 moves) are converted to multiple linear segments for now. I will include arc output to the DXF file if there is interest. I am not sure what people are using g-code to DXF conversion data for. If it is for visualization the linear approximation should be sufficient.
    I also added an option to export tool path data in CSV (Comma Separated Value) format. I am sure someone will find a use for the CSV format.
    I am open to suggestions for improvement.
    Scorch
    www.scorchworks.com
  3. #223
    Apr 2014
    Default Re: G-Code to DXF
    Thanks for this program. I can confirm it runs on win10 laptop. Yes, some funny arcs, but its a real time saver to recover lost drawings. Can always fill in the details, and delete extras myself.
    Great times we live in. With this app, and somewhat usable raster to vector conversion its actually possible to reverse engineer simple items. No probe for my router so havent gone there yet.
  4. #224
    Aug 2016
    Wayne,
    Thanks for great program works fine for me on Win 10 64 desktop.
    I would very much like to be able to remove the rapid tool movements above the work plane, is there a version, or do you know of a version that allows removal of rapids?
    Thanks again for the great work,
    RustySparks
  5. #225
    Member Tasdau's Avatar
    Jan 2018
    SE Michigan
    Hi All,
    I figured this is worth a bump.
    Wayne Hill's original program (post #15) and Jonk's (#36) were the only two that worked for me. Wayne's read all my G codes with the shortened syntax of G1, G2, G3, etc. but only used up to 4 decimal places for the coordinates. Jonk's read up to 5 decimal places but needed all the G codes replaced with their longer counterparts (G01, G02, etc).
    Thanks to all for a huge time saver!
  6. #226
    Mar 2004
    Michigan
    You are welcome. It seems a lifetime ago the program was written. Looks like it still stands up.
    Wayne Hill
  7. #227
    Member aliqahtan's Avatar
    May 2021
    I need a convert G-code to draw can you do that
  8. #228
    Sep 2005
    Quote Originally Posted by aliqahtan View Post
    What do you mean "to draw"? Are you asking whether it converts to *.drw?
    The whole thread here is about *.dxf and I'm certain that it there's no way possible for it to convert to drw.
  9. #229
    Member davidsnow001's Avatar
    Feb 2024
    Default Re: G-Code Ripper Now Exports to DXF
    Quote Originally Posted by scorch View Post
    This is a long shot, but I happened across this because I'm helping a friend convert over 5000 files that were written in ENC on Windows XP and all the drawing files are useless outside of that program as far as I can tell. I'm trying to convert the files to a usable format like dxf from the G-code. However, these are all customer jobs nested in sub folders. I would like to have the ability to point your tool at a directory and have it convert all the .gco files in every sub-folder with the same settings until it's done.
G-Code to DXF
G-Code to DXF
