PCB designer options for bCNC (Arduino UNO with GRBL) - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
Thread: PCB designer options for bCNC (Arduino UNO with GRBL)
  1. #21
    Member CitizenOfDreams's Avatar
    Nov 2012
    Default Re: PCB designer options for bCNC (Arduino UNO with GRBL)
    Depends on your workflow. To me it's easier to import just the traces and do everything else in CamBam.
  2. #22
    Oct 2016
    Brazil
    I tried to open different Gerbers and also .SVGs but the Open Gerber routine does not work.
    So I uninstalled FlatCAM 8.5 and installed 8.4.1 and then 8.3, always with the same result.
    I consulted the FlatCAM discussion group to have some hint of my problem and did not have answers. There does not seem to have much activity.
    Perhaps the problem is related to the installation and WinPython or my OS Windows 10, I do not know.
    I do not find more installation details on the website.
  3. #23
    Nov 2012
    Does FlatCAM open DXF files? You can open your Gerber file in CamBam and export it as DXF.
  4. #24
    Nov 2012
    Romania
    This is... actually weird; the file without the copper pour you tried seems to work fine for me in GCAM; this is what I get with your exact setting:
    Of course, it looks "enlarged" because the engraving tool chosen at step 2 is a very thick 1/8" milling bit; if I choose the "0.2mm v-tip" tool instead, I get a normal path shape, milling around the tracks:
    The rendering of the final piece looks like this (of course, 0.5mm would be much too deep to mill with a V-shaped tool; this rendering does not take that into account, it assumes a 0.2mm tool groove):
    There are only two reasons I can think of why it worked for me but not for you - either GCAM has problems working under windows 10 (I don't know what it does, I only test it up to Win 7; 10 is not supported although it should just work) or there might be something about the path name of your file that GCAM doesn't like (special characters or something similar): you might want to copy the file to a very simple path (c:\temp\ or something like that) and try opening it from there. Frankly, I have no other ideas why it wouldn't work for you...
  5. #25
    Oct 2016
    Brazil
    Could You send a screenshot of a small G-Code generated by CamBam, whatever it is? Can be from Notepad.
    I ask it because I have noticed that the G-Code compatible with GRBL (Arduino) seems to have their own dialect and all G-Codes I got so far are not compatible with the G-Code of GRBL.
    G-Code compatible with GRBL (Arduino) seems this format...
  6. #26
    Nov 2012
    Basic G-code commands (such as G0, G1, G2, G3...) are compatible across the board. I don't see anything in your screenshot that would not run on GRBL, Mach3, LinuxCNC or any other controller. What exactly makes you think there is an incompatibility? What are the symptoms?
    Here is the beginning of the file generated by CamBam:
    ( Made using CamBam - CamBam CNC Software )
    ( top_copper 2016-10-30 2:37:56 AM )
    ( T4 : 0.2 )
    G21 G90 G91.1 G64 G40
    G0 Z0.5
    ( T4 : 0.2 )
    T4 M6
    ( Profile1 )
    G17
    M3 S10000
    G0 X10.1913 Y5.7255
    G1 F25.0 Z0.0
    G3 F100.0 X10.4346 Y5.9906 Z-0.1 I-0.1415 J0.3741
    G3 X10.5168 Y5.9382 I0.6314 J0.8989
    G3 X10.5188 Y5.937 I0.5493 J0.9513
    G3 X10.5168 Y5.9358 I0.5472 J-0.9525
    G3 Y4.0332 I0.5493 J-0.9513
    G3 X10.5188 Y4.032 I0.5492 J0.9513
    G3 X10.5168 Y4.0308 I0.5472 J-0.9525
    G3 X10.2424 Y3.8063 I0.5492 J-0.9513
    G3 X9.8998 Y3.9998 I-0.3426 J-0.2065
    G1 X8.8998
    G3 X8.512 Y3.6979 I0.0 J-0.4
    G1 Y4.648
    G1 X9.382
    G3 X9.909 Y5.175 I0.0 J0.527
    G1 Y5.6997
    G1 X10.0498
    G3 X10.4346 Y5.9906 I0.0 J0.4
    G0 Z0.5
    G0 X8.3934 Y5.7824
    G1 F25.0 Z0.0
    G3 F100.0 X8.4498 Y5.835 Z-0.0207 I-0.2435 J0.3173
    G3 X8.7066 Y5.702 Z-0.1 I0.3 J0.2646
    G1 X8.193
    G3 X8.4498 Y5.835 I-0.0432 J0.3977
    G3 X8.7066 Y5.702 I0.3 J0.2646
    G0 Z0.5
  7. #27
    Jun 2008
    In flatcam are you using "OpenGerber" and NOT "Open G-Code"
    "Open Excellon" opens drill file
    You export G-Code when finished.
  8. #28
    Oct 2016
    Brazil
    Yes. GCAM does not recognize special characters that may exist in the Windows folder structure.
    I copied GCAM to the root (C: \) and Gerber to the sample folder GCAM. It worked.
  9. #29
    Nov 2012
    Yes, international characters are a common problem with some software...
  10. #30
    Nov 2012
    Romania
    Huh, I problem I didn't even know I had. Thanks for discovering it, I'll have to look into why this isn't already UTF-8 -capable...
  11. #31
    Oct 2016
    Brazil
    Only the G-Codes generated in plugins PCB-Gcode/Eagle and Gcodetools/Inkscape run without problem.
    All other G-Codes that I experienced, start the route and then immediately stop with the message "Error: Unsupported command".
    (Your script)...
  12. #32
    Oct 2016
    Brazil
    Inkiscape generated G-Code sample, that work in GRBL (Arduino), by bCNC controller.
  13. #33
    Nov 2012
    Does it tell you which command it does not like? Can you eliminate them one by one?
    P.S. I suspect it's the G64 code (cancel exact stop mode) that GRBL does not like. In that case you need to tweak the post-processor in CamBam so it does not generate G64.
  14. #34
    Oct 2016
    Brazil
    CNC screenshots tutorial with step by step as milling PCB generated in Fritzing (v. 0.9.3b) or other CAD application, with Gerber files converted into G-Code with CopperCAM and finally milled with bCNC ( GRBL / Arduino ).
    Youtube:
    If you prefer, the tutorial can be downloaded in .pdf here:
    https://drive.google.com/file/d/0B37...1ZNDZFTEE/view
    Fritzing: Fritzing Fritzing
    CopperCAM: https://www.galaad.net/coppercam-eng.html
    bCNC: https://github.com/vlachoudis/bCNC
