F-Engrave does not have a built in function for doing multi-pass cuts (yet?). If you need to take preliminary cuts the best way to do it is to set your Z zero position above your stock and run the full program (you will get some air cuts). Repeat as many times as required (while decreasing the Z zero height above the stock) until the Z zero position is at the top of your stock material.
