G-Code Ripper - Scale, Rotate and Split G-code - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 76 of 76
Thread: G-Code Ripper - Scale, Rotate and Split G-code
  1. #73
    Registered scorch's Avatar
    Dec 2010
    Default Re: G-Code Ripper - Scale, Rotate and Split G-code
    Quote Originally Posted by mroschk View Post
    Maybe the O-Codes Comes from the Postprocessor i use. It is called "PostDevTestMachine.vmid" and "PostDevTestMachine.gpp".
    I think i found it here, or maybe somewhere else.
    You might consider making a copy of the post processor files and edit them to fit your need. I am not familiar with the format of Solidcam files but generally post processor files are reasonably easy to edit especially if you are only looking to suppress some specific commands.
    It would be very GREAT if you could do some changes in your Ripper,
    an Option for the user to self decide to let the Ripper skip the O, D and A codes.
    I might change the behavior so the errors can by bypassed but I am not planning on working on that anytime soon.
    It would be very great if you could do that and recompile one Windows Version without the Debug Window.
    You can run without the black window by installing Python on your machine and running the .py file directly.
    Scorch
    www.scorchworks.com
  2. #74
    Oct 2016
    Germany
    Quote Originally Posted by scorch View Post
    Hello
    i anot firm enough to edit the PostProcessor, sorry.
    That means you will ot Change thins in the Ripper?
    That would be too bad !!
    Matthias
  3. #75
    Oct 2012
    Santa Fe, Tx...USA
    You are asking a bit much for some freeware. Mirror in your CAD/CAM.
  4. #76
    Feb 2009
    Bulgaria
    Hi scorch,
    Trying to migrate to Linux as much as possible. Installed the dependencies and ran the .py file (Ubuntu). And surprise - it works
