Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 04-13-2005, 10:21 PM
Sanghera is on a distinguished road
2 drivers for 1 motor possible?
I was just wondering if two drivers can be used to run one motor. Would you be able to double the current rating and voltage rating, or would this be not possible?
Thanks.
Old 04-14-2005, 12:18 AM
H500 is on a distinguished road
It won't work with a chopper drive. They would intefere with each other. Also, doubling up drives won't increase their voltage ratings.
Old 04-14-2005, 12:21 AM
What about if they were driven from the same parallel port pin?
Thanks.
Old 04-14-2005, 03:02 PM
The parallel port pin only tells the controller to move. The controller does the coil drive timing & current limitation, so it won't make a difference.
Old 04-14-2005, 03:43 PM
I see, it was worth a question anyway. I figured if it was possible, you could get way better ratings with a smaller chip if you double them up.
Thanks.
Worth a Thousand Words Chunky General Electronics Discussion 41 05-29-2005 05:18 PM
Help picking drivers sinnedD Stepper Motors and Drives 5 03-12-2005 10:42 PM
I recommend Rutex drivers. ynneb Servo Drives 34 02-02-2005 10:36 AM
Cnc Motor Drivers A. Shuford DIY-CNC Router Table Machines 1 09-04-2004 10:26 AM
3 Axis drivers (a list wannabe) Konstantin General Electronics Discussion 3 03-26-2004 01:22 AM
