| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
Roman Black, the guy who designed the brilliant Linistepper controller has come out with a new design for a higher current, ultra simple, minimal component count, chopper type stepper controller. And of course, we have a very nice kit available, which has to be the simplest, quickest kit for a micro-stepping controller ever. The SLAm Stepper, based on the Allegro SLA7062M, is a very quick and easy to build, 3 amp 40 volt per phase, chopper, unipolar stepper motor controller. With only 15 components, and a very frendly PCB, you can have your motors spinning quicker with this design than just about any other. Here is the design: ![]() PCB LAYOUT? We don't have a board layout yet that would be good for hobby / home etching; the board in the kit is double sided with a lot of vias. Hopefully someone will come up with a good version soon which we will be happy to post on the site. CONTEST! Just to help get that started: The first person who comes up with a workable single sided layout, I'll send a free kit of parts for one SLAm driver (good for a single axis) and a break out board (good for 4 axis) with cables to get you hooked up and running. Features
![]() KIT: The kit includes all the components and a professional double sided PCB with top silkscreen, thru plated holes and lead free construction. (RoHS compliant). You add your power supply, motor, heatsink, and standard step and direction signals from Mach 3, TurboCNC or other CNC software.
Quantity breaks available Like any chopper type of driver, the SLAm is not as smooth as our other, Linistepper, linear driver and you may need to add external, mechanical resonance damping in extreem cases. The SLAm is more powerful, and will run cool, but your motors may get a bit hot, so make sure they have some air. |
| Just curious. I don't see any mounting holes. How is this board intended to be mounted? I'm guessing, mount to the heatsink and hang the board off the chip? (Is there a mounting hole hiding in the corner behind the header connector?) Gary |
| And how has that worked out? What was needed? I'm guessing at least a small R on each output to balance the currents? Gary |
| There is a mounting hole in the corner between the PMinMO connector and the motor/power connector, and there are no traces in the corners near the SLA so you can drill your own mounting holes as you like in that area. |
| The board is very compact and lightweight, and quite well supported at one end by the SLA chip itself. At the other end there is a PCB hole in the corner between the 2 connectors (as James said). Those 3 points total give plenty of support. Re the 7078, I prefer the 7062, it still has 16th microsteps but the current is set by external resistors (not a little trimpot). The current does not need to be adjusted it should just be set at the proper value for the motor when the driver is built, and removing the trimpot from the design removed another cause of user error and failures from incorrect adjustment. It also eliminates a very common form of electrical failure as trimpots are one of the most likely failure components especially in a high vibration environment. The SLAmStepper was designed to be small, very fast to build, and offer excellent performance and reliability. They are small enough to be built INTO the machine itself, or housed near the stepper motor even on small machines. My machine has the 3 SLAmSteppers in a little box behind the gantry. |
| If anyone wants to see SLAmSteppers installed on a small router with 300 oz-in steppers, I have posted some pictures in this build thread; DIY hobby small plastics mill/router |
I just tried my hand at single sided layout for this schematic. Attaching the board image and eagle files. |
| Looking at the pics of Roman's board, I think I might have got the chip backwards (heat sink side facing the inner side of the board). I flipped it and redid the board, with a few other minor tweaks. It's probably quite clear to all that I am an eagle newbie. Please help fix any issues, so we have a usable board. TIA! |
#11
I've asked Roman to look over your layout and see if it's workable, and if so, I'll send out the kits. India huh? I should have specified that the postage is not included, but I'll go ahead and pay it this time. |
#12
| Hi Quadtech and James, I haven't checked all the wires are connected to the right spots, but there are a few layout issues I noticed straight off. The 2 wires from the chip back to the current feedback resistors carry full motor current so they should be the same larger size as the 4 motor tracks. Getting the resistors closer to the chip so the current paths are smaller would be good. I know it's hard to get a single sided layout to perform really well, but nobody will really be expecting a single sided SMPS driver to perform as well as a proper plated through hole PCB so you probably just need to improve it to a reasonable level. If you can, make the length of the tracks the same from the chip to each set of the current sense resistors. That includes the 2 tracks from the ground side of the resistors back to the main cap. If possible the chip, sense resistors and main cap should be close together with short direct tracks. The other parts can be further away. The 5v cap should also be closer to the chip which should be easy enough. The other layout problem is the placing of some of the solder pads, especially the ones on the wire jumpers. If possible for a good single sided design the places where the user has to solder should be well spaced away from any other tracks, to reduce the chance of shorts and make soldering easier and more reliable. Also the size of the solder pads should be larger if possible to make for easier drilling and soldering when people make their own PCBs. Those tiny square pads on the wire jumpers are not good. |
| Linistepper - cheap unipolar microstepping driver | lietuvys | Open Source Controller Boards | 35 | 12-08-2010 02:17 PM |
| Linistepper (unipolar driver) with aligned transistors! Eagle files | patriciooholegu | Open Source Controller Boards | 2 | 08-28-2009 11:38 AM |
| Sla7062m | shahidmk | Open Source Controller Boards | 7 | 08-02-2009 07:18 AM |
| A circuit board for the SLA7062M microstepping driver | Edison4 | Product Announcements & Manufacturer News | 5 | 05-04-2008 04:59 PM |
| Where can I find some SLA7062M driver chips? | radicooldude | General Electronics Discussion | 7 | 07-31-2006 09:15 PM |
