| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
I've decided to go with the DIY route for my Breakout Board and Drivers. I've narrowed it down to 2 drivers which I can't seem to choose between, and a bunch of Breakout Boards which I really don't know the difference. So a little help would be appreciated ![]() Driver #1: THS Engineering A3977 Stepper Motor Driver http://www.thsengineering.com/projec...3977proto.html Driver #2: Linistepper V.2 http://www.piclist.com/tecHREF/io/st...step/index.htm Both of these drivers do micro-stepping, and both put out enough voltage/amperage to drive the motors I'm looking at (which are 6-wire). The only real difference is the A3977 board drives Bipolar, and the Linistepper drives Unipolar Motors. I guess it comes down to the question, will 6-wire unipolar motors make any more/less power wired bipolar over unipolar, or will the torque stay the same? As for the Breakout Boards, there's just a bunch listed off www.PMinMO.com http://pminmo.com/PMinMOwiki/index.p...4axisinterface http://pminmo.com/mhelsinterface/mhelsinterface.htm http://timeguy.com/cradek/cnc/stepper-drivers http://pminmo.com/db25/basicBOB.htm I guess I'm just wondering which of those is the "best"? Thanks, - Jesse |
| Hi Jesse, I don't have time to review the various links but, as nobody else has answered you, I'll touch on the torque issue. The unipolar stepper is basically a bipolar stepper with a center tap on each of the windings. This makes the drive circuitry simpler because instead of a full bridge for each coil, power is applied to the center taps and the driver chooses polarity by connecting the appropriate end of the coil to ground. Only being able to use half of the windings at any given time is the price you pay for this drive simplicity. Less efficent use of the winding space gives a unipolar stepper motor less torque than the same motor would have in a bipolar configuration. Pete Last edited by probinson; 12-05-2009 at 08:41 AM. |
| Need Help!- Choosing the Right Oscilloscope | joprinz | General Electronics Discussion | 7 | 03-08-2009 10:50 PM |
| Help choosing lathe | dannirr | Mini Lathe | 4 | 04-13-2008 07:01 AM |
| Help choosing steppers and drivers | Aaronem | DIY-CNC Router Table Machines | 4 | 03-09-2008 10:06 PM |
| Need help choosing | lmartin1001 | Benchtop Machines | 2 | 10-13-2006 02:24 AM |
| NEED HELP Choosing A Lathe | InventIt | General Metal Working Machines | 0 | 11-21-2003 06:28 PM |
