Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
  #25   Ban this user!
Old 06-12-2005, 04:08 PM
mannster is on a distinguished road
The posted 4030 4013 circuit sets the phase pattern, not me.
***UPDATE !! I bypassed some pulldown resistors I used for the STEP DIR inputs on the 7474 7486 circuit and it FIXED IT ! I used the 74HC~ series which requires higher voltage than the 74HCT~ series which is designed for TTL inputs. So, I think the pulldown resistors were lowering the voltage too much and not allowing the ICs to operate properly. The DIR input seems to not cause problems if I let it float while testing, but that shouldn't even be an issue when it is connected to TTL.
I still need to see what is wrong with the 4030 4013 combo
fet 3 15 amp 3 axis driver board (stepperworld) mike10 Stepper Motors and Drives 17 04-29-2005 10:30 PM
Hypothetical 1 axis 3977 board pminmo Open Source Controller Boards 12 04-14-2005 03:41 PM
4 axis control board question cnctoolman Hobbycnc (Products) 1 04-01-2005 03:30 PM
HobbyCNC 3 axis controller board review CNCadmin Hobbycnc (Products) 32 02-10-2005 04:43 PM
Troubleshooting the OS discrete single axis board Konstantin Open Source Controller Boards 3 08-24-2004 04:31 PM
