Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 10-07-2009, 07:39 AM
secad is on a distinguished road
3-phase BLDC current sensing questions
Hi folks. Has current monitoring on 3-phase BLDC servo drivers been discussed on this forum? The sort of issues I am thinking of are ADC conversion timing, bandwidth of current sense circuit, opamp overload by the leading Rsns*Isns voltage spike, reverse current sensing, etc.
I am using the Freescale MCF51AC256 (2 PWM timer modules) to control 2 tightly coupled motors with sinusoidal 3-phase drive through International Rectifier IRAM136-3023B (150V 30A) inverter drive modules.
The problem is noisy, unreliable current readings interfering with attempts at torque limit control.
Any thought?
Old 10-07-2009, 08:21 AM
nhatson.elec is on a distinguished road
you can use shunt senses, for opto sense you can use HCPL-7800 or lem sensor
b.r
Old 10-07-2009, 10:44 AM
Thanks nhatson.elec, the HCPL-7800 looks really nice. I had a much less elegant arrangement with linearized optocouplers & op amps.
This looks suitable for direct measurement of each motor lead phase current. I was hoping to derive this from the current sense resistor in the IRAM module, but the sense voltage is only present for a short time period (a few uSecs) if the BAT+ voltage is high and the motor RPM is low (low back emf).
This makes it hard to reliably trigger the ADC within the pulse period but while avoiding the leading edge spike.
Is there some cct configuration that can get around this?
I have the sneaking feeling that the HCPL-7800's in the motor phase leads are the way to go, & just leave the module's internal Isense resistor to do its job of protecting the module.
With the HCPL-7800's, if my understanding is right, I should be able to take ADC readings of phase current any time I want, as it should be relatively constant due to motor inductance. Does this sound right-ish?
Help with 4-pin current sensing resistors - useful or fizzers ? nick mulder General Electronics Discussion 7 04-22-2009 11:37 PM
low-side isolated current sensing ? (0-10 A) andy55 General Electronics Discussion 10 04-22-2009 11:20 PM
Current sensing switch... WilliamD General Electronics Discussion 7 04-22-2009 11:11 PM
IRAMS Current Sensing xjack Phase Converters and VFD 1 07-21-2007 01:41 PM
Current sensing on stepper originator General Electronics Discussion 6 12-01-2006 02:48 AM
