Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 10-02-2009, 08:55 PM
vbpl14 is on a distinguished road
Hbridge using BTN7970
I am considering using the Infineon BTN7970 as the power stage of a stepper motor controller. Does anyone have any experence using this device? One specific question I have is can it be used with a 28 volt power supply? The data sheet is unclear as to which patameters change when using a supply greater than 18 volts. I plan to use an arm7 processor to drive the bridge with pwm. I hope to use the integal current sense output fed into the micro analog to digital converter to control the current.
EMC2 - Pluto P (or Mesa 5120) - HBridge - DC Brush Servo DNB LinuxCNC (formerly EMC2) 20 11-08-2007 01:53 AM
Who is the Hbridge expert originator General Electronics Discussion 12 06-17-2006 11:45 AM
