Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 03-11-2005, 06:13 PM
sp00k1e's Avatar
sp00k1e is on a distinguished road
Driver recomendations
My Hans Wedemeyer L297/8 board just blew up. The magic electronic smoke escaped from the 298 when I turned on the power. So it is maybe time for a change. I have had no problems with this chipset even though I built it on veroboard and was planning on upgrading it to a prober milled pcb. I use a bungard CCD pcb Mill at work.
My question is what are the advantages over the 297/8 chipset, if any, of the other chipsets designs around. I fancy Alans LMd18245 PICSTEP board, but in the UK the chips are about £11 each (unless anyone knows a cheaper source) and will my machine run faster with more power or be about the same. I have looked at pminmos circuits maybe you could answer seeing as you have seemingly built every combination available? I was going to build your 3977 board but the cost of importing the chips from the US was prohibitative, as i cant find them over here.
I have 6 lead 2A steppers to control
Thanks Paul
Old 03-11-2005, 07:27 PM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
You can get the 3977 in the UK from Farnell.
http://uk.farnell.com/jsp/endecaSear...KU=4126075&N=0
£3.72 ea. Not sure if tat includes VAT though.
Regards Terry.....
Old 03-11-2005, 09:47 PM
pminmo's Avatar
pminmo is on a distinguished road
Paul,
What is your power supply voltage? What is your coil voltage or resistance?
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 03-11-2005, 10:52 PM
andyew's Avatar
andyew is on a distinguished road
spookie Paul,
as mrbean Terry said, Farnell (Newark actually) has em in stock..... A3977SED is listed there quite cheap... from my part of world, it takes 2 weeks from order to postman reaching my house since it's from Newark US.
Good luck and phil is really helpful, he will guide u the right direction, just bear with him sometimes, look at his signature u will know...... :P
Andy
Old 03-12-2005, 04:39 AM
sp00k1e's Avatar
Yes Farnell has the 3977 in stock, but since they are from Newark the postage is another £13, not too bad i suppose if they are what I want. My power is a rectified smoothed 25v toroid so about 35v, but that could easily change, and the X and Y motors are Sanyo Denki 103H7126-0440, I cant find the specs at the moment but I seem to remember about 3.5V, rated 2A on the case. The Z at the moment is a 6V printer motor.
Old 03-12-2005, 11:49 AM
pminmo's Avatar
Under 2.5 amps and 35V the 3977 is a great chip. But you have to be able to solder well and very fine. The L297-8 is my second choice. One the pricey side is the picstep board, but the driver is a gem.
Phil
Old 03-12-2005, 01:40 PM
MrBean's Avatar
Gold Member
That's not good. All the orders I've placed with them have not had postage charged. Maybe I've just been lucky.
Regards Terry.....
Old 03-12-2005, 01:55 PM
sp00k1e's Avatar
I think then I will try and sneak a few 3977 on my next order and try and hide the postage cost
Old 03-18-2005, 05:32 PM
sp00k1e's Avatar
Well I have managed to get my 3977, almost double the cost due to the postage from the states, but delivered in less than 48 hrs.
I have milled one board to try, a slightly modified version of phils circuit so that I could transfer it onto the PCB mill at work. only a few more components needed and then we will see what it can do. You can see I lost a couple of pads from the top of the chip when I was trying to clean up the remaining copper, a couple of wire links will sort that out. Next one I will do a full mill to remove the excessfrom around the chip.
Paul
Old 03-19-2005, 12:19 AM
pminmo's Avatar
spook1e,
Looks good, keep us posted.
Phil
  #11   Ban this user!
Old 03-19-2005, 02:50 AM
H500 is on a distinguished road
The board looks good. 35v might be bordering on the high side. When the motors are decellerating they put out back emf that could potentially cause the supply voltage to go too high and zap the 3977.
  #12   Ban this user!
Old 03-23-2005, 06:32 PM
sp00k1e's Avatar
Well ive built the 4 axis breakoutboard and one drive, and now have it almost working, when I enable the drive the motor locks as expected, but it just very quietly whispers and wont move, it is probably a fault on my remanufactured boards but just to check, and before i can get my scope from work, the double sided version circuit has a 10k pullup on the dir signal but the single sided doesnt. I understand that in general the printer port is TTL but it may be open collector, but i guess the 7414 should sort that out shouldnt it?
Paul
PIC Open source Servo Driver Schematics development? Rossz Open Source Controller Boards 90 10-26-2011 04:37 PM
Good driver for Omron U75030VA-BS1 servomotor? Vikketsi Servo Motors and Drives 2 02-26-2005 03:53 PM
servos motor controled by stepper motor driver? mike10 Servo Motors and Drives 1 01-03-2005 06:05 PM
Fun with floppy stepper and driver Konstantin General Electronics Discussion 5 03-08-2004 02:18 AM
Selecting stepper driver components... fyffe555 General Electronics Discussion 0 09-26-2003 10:50 AM
