Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
View Poll Results: How do you rate Tom McWires driver circuit?
I built it and it works well for my needs. 3 27.27%
I built it but it doesn't do what I need it too. 2 18.18%
Didn't try it but based on my electronics experience I consider the design flawed. 0 0%
This is the first I've heard of it. 6 54.55%
Voters: 11. You may not vote on this poll
Old 05-26-2009, 07:53 PM
technovative is on a distinguished road
Who has used Tom McWires driver circuit?
I get the impression that most folks who use this forum prefer chopper/pwm based driver circuits and I'm curious if any of you have used Tom McWires driver circuit as posted in this article http://www.instructables.com/id/Easy...and-Driver-ci/? If so what has your experience with it been, and how do you rate it?
Old 06-23-2009, 03:12 AM
yaycnc is on a distinguished road
its quite a basic circuit. it only does full stepping (low torque/current) mode which might be all you need.
if you want a similar hardcoded design for high torque full stepping there is one here http://commons.wikimedia.org/wiki/Fi..._Driver_CD.png
uses 2 chips too.. just drop it in to mcwires circuit to replace the logic.
having everything hardcoded is nice and reliable and easy to set up (no programming), but i would prefer using a programmable microcontroller. which means you can swap between any driving scheme (full/half etc) with a flick of a switch. and its no more expensive really.
I made a thread here with a really simple pic driver that does full/half stepping for 2 motors.
http://www.cnczone.com/forums/showpo...71&postcount=1
I am sure there are far better pic based drvers out there, but mine is simple and good if you only want half/full stepping.
another cheap option is the linistepper.
Old 08-02-2009, 11:08 AM
JohnnyVegas's Avatar
JohnnyVegas is on a distinguished road
I am rebuilding just a single drive from his design to test some samll motor finds. My first attempt at this circuit failed - I seriously OVERPOWERED it by mistake. I had a few bad parts.
I will post as I complete the testing.
Tags
instructables, step cheap, tom mcwire
Parallel L298N driver circuit help Sidco7 Stepper Motors and Drives 12 02-28-2011 09:56 PM
A circuit board for the SLA7062M microstepping driver Edison4 Product Announcements & Manufacturer News 5 05-04-2008 03:59 PM
need help Differential Driver/Receiver circuit markus_detroy Servo Motors and Drives 9 04-17-2008 09:02 PM
stepper driver circuit.. comments? integerspin Stepper Motors and Drives 0 09-21-2007 10:27 PM
RQ: Bipolar stepper motor driver circuit elektronchika Stepper Motors and Drives 2 12-21-2005 05:29 PM
