Results 1 to 8 of 8
Thread: brushed servo drive with PWM & direction input
    Jan 2007
    Slovenia
    Lightbulb brushed servo drive with PWM & direction input
    Hello!
    I would like to start discouse how to design circuit for large brush dc servo motors with PWM & direction control signals and IR compensation mode.
    So, PWM & direction signals are converted to analog .
    Jul 2003
    Holmen, WI
    I have goofed around with a simple h-bridge design that uses pwm+pwm for input. The latest version has been lightly tested with good luck. Would not take much to make it pwm+dir. (a bit of logic). It uses lowside current limit and blanking. (designed for about 20khz pwm)
    Check my *cough* logic - H-bridge design.
    Large Brushed servo setup on the cheap (WIP)
    http://www.electronicsam.com/images/...tcurrentlimit/
    (use at your own risk )
    sam
    Jan 2007
    Slovenia
    Question
    Would this shematics work? It is taken from UHU servo controller.
    I would like to avoid ic4071 .
    I would go up to 180 -200 Volt and around 12Amp
    Of course i would add opto for bouth pwm channels and enable to flip-flop data pin
    Attached Images Attached Images
    Jul 2003
    Holmen, WI
    They are using diodes instead for the or gates. (I just didn't like it - just me ).
    I would really look at blanking. Otherwise for higher current you have to filter the crap out of the current limit sensing to get rid of the mosfet/igbt turn on spike.
    sam
    Jan 2007
    Slovenia
    i made some modification - check it
    You will se ? becouse i do not understand what it does.
    Could i use 0,1R 5Watt resistors insted of 0,015 ( R11 ) ?
    Jan 2007
    Slovenia
    samco,
    could you export pcb circuit into gerber files ?
    Jul 2003
    Holmen, WI
    what you have questioned is the blanking. The flipflop fires an aprox 5us pulse during each time the pwm signal is rising which causes the transistor to turn on for 5us. That inhibits the current sense for that amount of time (as the mosfets/igbts first turn on).
    I am using eagle - I will have to look to see what kind of export I can do.
    sam
    Jan 2007
    Slovenia
    Question
    Shematic to check? Would current limit work?
    1. AC servo Step Direction drive
      By professor in forum Servo Motors and Drives
      Last Post: 11-10-2007, 11:07 AM
    2. How to drive Analog Servo Input +/- 10V
      By gurvy in forum General Electronics Discussion
      Last Post: 05-31-2007, 12:31 AM
    3. Brushed Servo Drive Sizing
      By GEMorris in forum Commercial CNC Wood Routers
      Last Post: 09-23-2006, 12:43 PM
    4. step and direction control for opto22 servo drive
      By drewgarth in forum Servo Motors and Drives
      Last Post: 05-21-2006, 02:31 PM
    5. Brushed servo drive replacement
      By motordude in forum General Electronics Discussion
      Last Post: 07-06-2004, 02:09 PM
