Results 1 to 2 of 2
Thread: Questions about Current Limiters
    Jan 2009
    Question Questions about Current Limiters
    Hello,
    I have started to huild my cnc machine (see my thread http://www.cnczone.com/forums/showth...93749#poststop). I am thinking about building the 3 axis PIC board from pminmo.com (Alexander's). Is this controller any good? My motors are unipolar 2.9 volt 1.2 amps. I would like to use a pc power supply to power the 3 motors and the logic to the controller. Will this work? Also, I read that you need some form of current limiter for your motors otherwise it will fry the mosfets. Is this true? If so, what kind of current limiter should I use (cheap as possible)? Any help would be greatly appreciated.
    Registered hesham morsy's Avatar
    Apr 2006
    egypt
    the Current limiter in the same peg http://www.pminmo.com/3axisPIC/3axisPIC.htm
    3 Axis Pic discussion at pminmo forums
    http://pminmo.com/phpBB2/viewforum.p...5a72d80ba6c86c
  1. CNC mill questions - thrust bearings, leadscrew mounting, general questions
    By tonofsteel in forum DIY CNC Router Table Machines
    Last Post: 02-03-2012, 04:42 PM
  2. Brass vs Aluminium Vs Steel, questions, questions and questions...
    By alexccmeister in forum General Metal Working Machines
    Last Post: 08-15-2011, 01:40 PM
  3. Voltage and current questions
    By jcbeck84 in forum Stepper Motors and Drives
    Last Post: 01-09-2009, 12:32 AM
  4. Questions about current limiting
    By uplb in forum General Electronics Discussion
    Last Post: 10-04-2008, 12:19 PM
  5. current over
    By bbrreid in forum General Electronics Discussion
    Last Post: 08-01-2005, 05:43 PM
