Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 01-12-2005, 12:07 AM
TinkerDJ is on a distinguished road
lmd18245 or sla7051m
Has anyone designed a driver with either the national lmd18425 or the allegro sla7051m, i have sets of both and was wandering if it is worth the time and effort to build a driver board for one of them.
Old 01-12-2005, 02:21 AM
santiniuk's Avatar
santiniuk is on a distinguished road
I can recommend Alan's Picstep boards for the LMD18245 I.C's.
It uses a Microchip Pic16F628A and a handful of discrete components.
Works a treat.
Details at :-
http://www.fromorbit.com/projects/picstep/
Good luck.
Old 01-12-2005, 03:51 PM
H500 is on a distinguished road
The 18245 is a better chip if cost is no issue. It is bipolar and support microstepping.
You will need two of them per motor.
I will be testing an AVR based chopper circuit similar to the 7051, shortly.
Old 01-12-2005, 06:38 PM
Yeah i found that out about the lmd18245 chips, i guess i should have looked at them harder. I think i will focus a design on the 7051 chips or go with one of the open source boards. For now i will stay away from a pic driven board. I would like to build a board per axis and then use a pic18f452 to control everything from the com port or usb if i get a chance but thats all later. Maybe next winter. As for now i just want to get some boards done for the new steppers i have. Build my bigger router and go from there. As it is bitterly cold out right now i am more interested in doing indoor electronics type stuff rather then outdoor wood cutting router building type stuff. Thanx.
Old 01-14-2005, 10:47 AM
kfong is on a distinguished road
Definitely go with the lmd18245 if you can afford it. The lmd18245 is much better at dissipating the heat. It has better specs and can withstand 6amp surges. It has a 12-15amp burst rating as well. Here is our designs, very reliable.
http://www.embeddedtronics.com/microstep.html
http://www.embeddedtronics.com/microsteppld.html
Not open source but the code is posted as well as the schematic, design is proven. Boards are professionally done and are available if you find it too much of a bother to layout your own.
Kin Fong
Robotics, CNC, and Controllers
Old 01-14-2005, 11:45 AM
BobLWeiss is on a distinguished road
Yup like they said, the LMD chip is real nice. I built the PicStep boards and they are working great. Do a search on here for PicStep and you'll see what I mean.
Old 01-14-2005, 08:53 PM
Actually i just got some lmd18245 chips in the mail. Problem is in my infinite wisdom i only ordered 3. Well i will work on the 7051 board design for now. I designed a board last night for the 7051 chips. But i need to trouble shoot any problems before i make anymore. I've actually looked at both picstep board and the embedded board. Both are very nice designs. Basically i am looking at building a controller that uses the pic18f452 and then seperate boards per axis. What the driver chips or arangements will be i don't know. Basically i'm reinventing the wheel and hoping to learn how it all works in the end. One thing i need to look at is either building or buying a pic programmer. But for now i will work on the board layouts and try and get my small router to work cutting pcb's. H500 keep me apprised of your board design. I have only played around with pic micro stuff but i have heard alot of good things about the AVR's.
Old 01-14-2005, 09:48 PM
I have used PIC's for a long time now and I am biased towards them. They have never let me down yet in terms of power and speed. Their website offers a wealth of knowledge and support is great.
Old 01-14-2005, 10:06 PM
My absolute favourite part of using pics is that they will give samples. I blew a pic with my last board design. So i need another programmer. I haven't even tried any AVR stuff yet. But the robot community seem to really like them. But i am keeping my options open and making a stable board that will work is mostly what i am trying to accomplish.
Old 01-14-2005, 10:31 PM
pminmo's Avatar
pminmo is on a distinguished road
Atmel is pretty good about samples also. Three years ago when I was looking to get back into micro's, I originally looked to go with the PIC's or an updated version of the 8751 family, then I got a hold of some AVR literature. At that time the PIC's only had 8 bit a-d's and the AVR's had 10bit a-d's. When I found BASCOM's 2K basic compilier was free with an integrated development tools, I went the AVR route. I've never looked back. There is one part of the AVR family I feel is missing, a 14 pin DIP part. You jump from 8 pins to 20 pins. For example, a simple unipolar driver with 4 ouput drive lines a step and direction input will fit their 8 pin parts, but if you want an input for enable you have to jump to the 20 pin part. There not expensive $2, but would like the smaller foot print.
Phil
  #11   Ban this user!
Old 01-14-2005, 10:54 PM
Through some of the web sites there are plus and minus's for all the micro controllers, basically every manufacture has one. I'm not pro pic or anti avr just inexperienced. I do have some knoledge of C programming is there a C programmer for AVR, i have one for pic's.
  #12   Ban this user!
Old 01-14-2005, 11:20 PM
pminmo's Avatar
A good starting point for avr's:
http://www.avrfreaks.org/
Free compiler:
http://www.avrfreaks.org/AVRGCC/
Phil
