Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 03-30-2009, 08:23 PM
*Registered User*
Zoidberg is on a distinguished road
Cool DIY autotuning servo driver
Anyone up for a collaboration project? The best open source servo driver ever!
Let's talk specifications:
Written in C/C++.
Based on Amtel AVR ATmega48, 88, 168 (differ only in memory sizes).
Easily portable to other models by using port/pin defines.
Minimalistic board design.
Programmed on board with ISP.
Inputs/outputs:
Enable input.
Step/dir or quadrature input.
Encoder input 1x, 2x or 4x.
Current sensing with A/D converter.
Fault output.
Auto tuning button.
Reset button.
Control:
2 PID loops, torque loop controls output PWM, position loop controls torque.
Autotuning with Ziegler Nichols method.
Settings:
Max current limit (over the limit = fault).
Max continuous current limit (over the limit for 1? second = fault).
Max error limit (over the limit = fault).
Max PWM output.
Step multiplier 1-10.
Safety:
Missing encoder check (Max? PWM output for x loops without any encoder interrupt = fault).
Because the driver is open source and built for a specific use by each user, the settings is set at compile time by defines, and therefore you would not need any RS232, only 1 button to initialize the autotuning and 1 button for reset! It would reduce the size and cost of the driver a bit, as you don't need DB9 connector, the MAX232 ic and the supporting components! It also reduces the memory requirement for the µC as you don't need a communication protocol.
Comments?
Old 03-30-2009, 08:33 PM
*Registered User*
I have written the encoder input earlier!
It works by setting interrupts for the 2 encoder input pins:
Rising edge on pin A, nothing on pin B = 1X
Logical change on pin A, nothing on pin B = 2X
Logical change on pin A, logical change on pin B = 4X
Code:
ISR(INT0_vect)
  if(bit_is_set(PIND, PD2))
    if(bit_is_set(PIND, PD3))
      ProcessVariable--;
    } else {
      ProcessVariable++;
  } else {
      ProcessVariable++;
    } else {
      ProcessVariable--;
ISR(INT1_vect)
      ProcessVariable++;
    } else {
      ProcessVariable--;
  } else {
      ProcessVariable--;
    } else {
      ProcessVariable++;
Old 03-31-2009, 12:43 AM
*Registered User*
I have done some coding now. I dropped the quadrature input, enable input and PORT/PIN defines.
Implemented:
Save and Load PID parameters from eeprom.
Step/Dir input with step multiplier.
Encoder input, 1X, 2X and quadrature.
I have only used notepad so i don't know if it will compile!
Code:
#define F_CPU 20000000U //20 MHz External Oscillator
#include
#include
#include
#define sbi(port, bit) (port |=  (1 << bit))
#define cbi(port, bit) (port &= ~(1 << bit))
// SETTINGS //
#define MaxCurrent 255
#define MaxContinuousCurrent 127
#define MaxContinuousCurrentTime 1000
#define MaxError 1000
#define MaxPWM 255
#define StepMultiplier 1
//#define EncoderMode1
//#define EncoderMode2
#define EncoderModeQuadrature
// DECLARATIONS //
typedef struct
  short int PTorque;
  short int ITorque;
  short int DTorque;
  short int PPosition;
  short int IPosition;
  short int DPosition;
} pss //PID Setting Structure
pss EEMEM EEPROM_Data;
pss PidSettings = {0,0,0,0,0,0};
long int SetPoint = 0;
long int ProcessVariable = 0;
void Initialization();
void AutoTune();
void TorqueLoop();
void PositionLoop();
void LoadSettings();
void SaveSettings();
// MAIN //
int main(void)
  LoadSettings();
  Initialization();
// FUNCTIONS //
  cbi(DDRC, DDC0); //Enable Step input - Pin 23
  cbi(DDRC, DDC1); //Enable Dir input - Pin 24
  sbi(PCICR, PCIE1); //Enable pin change interrupt
  sbi(PCMSK1, PCINT8); //Enable PCINT8 - Step input
  cbi(DDRD, DDD2); //Enable encoder A input - Pin 4
  cbi(DDRD, DDD3); //Enable encoder B input - Pin 5
  cbi(EIMSK, INT0); //Clear registers
  cbi(EIMSK, INT1);
  cbi(EICRA, ISC00);
  cbi(EICRA, ISC01);
  cbi(EICRA, ISC10);
#ifdef EncoderMode1
  sbi(EIMSK, INT0); //Enable interrupt A
  sbi(EICRA, ISC01); //Set rising edge A
#endif
#ifdef EncoderMode2
  sbi(EICRA, ISC00); //Set logical change A
#endif
#ifdef EncoderModeQuadrature
  sbi(EIMSK, INT1); //Enable interrupt B
  sbi(EICRA, ISC10); //Set logical change B
#endif
void AutoTune()
void TorqueLoop()
void PositionLoop()
void LoadSettings()
  eeprom_read_block((void*)&PidSettings, (const void*)&EEPROM_Data, sizeof(pss));
void SaveSettings()
  eeprom_write_block((const void*)&PidSettings, (void*)&EEPROM_Data, sizeof(pss));
// INTERRUPTS //
ISR(PCINT1_vect) //Step Dir input
  if(bit_is_set(PINC, PC0))
    if(bit_is_set(PINC, PC1))
      SetPoint -= StepMultiplier;
    } else {
      SetPoint += StepMultiplier;
ISR(INT0_vect) //Encoder input A
      ProcessVariable--;
    } else {
      ProcessVariable++;
  } else {
      ProcessVariable++;
    } else {
      ProcessVariable--;
ISR(INT1_vect) //Encoder input B
      ProcessVariable++;
    } else {
      ProcessVariable--;
  } else {
      ProcessVariable--;
    } else {
      ProcessVariable++;
#endif
Old 03-31-2009, 11:20 AM
samco is on a distinguished road
I think you may want to look at a different autotuning method than ZN. I have used ZN manually and within emc there is a PID with ZN tuning built in. It gets you sort of close - but in the end a bit of manual tuining is required.
(I don't know what is out there)
Good luck
sam
servo driver for yaskawa chriswp Servo Motors and Drives 5 02-11-2009 04:17 AM
Phelps CNC Servo Driver dgoddard General Electronics Discussion 0 08-28-2008 03:05 PM
Servo driver karl1 General Electronics Discussion 21 03-21-2007 08:51 AM
Basic driver for an AC servo phantomcow2 Servo Motors and Drives 1 12-18-2005 11:57 PM
have anybody making servo driver? masaV Servo Motors and Drives 0 06-20-2005 03:10 AM
