| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
Anyone familiar with the "Tachus 42" designed board? I'm a bit of a newb, and I would like to build this board. The problem that I'm having is understanding the accompanying chopper board plans. The values of the so called "current setting resistors" are not listed. There are 3 sets of 5 resistors in paralell. I presume this must be taylored to the motors being used? But how? Also printed is " R5+R4 (supply-10) /0.05". This refers to a pair of resistors in series that presumably limit the voltage to the steppers. There are two other pairs of resistors in the same configuration, R18 and R17, R31 and R30. Are these to be the same values as R5 and R4? http://pminmo.com/3axis/3chprschematic.pdf Is there a better board that I should be considering? |
| Suggest you look at PMinMO's bulletin board. http://pminmo.com/phpBB2/ there is a section for the tachus42 board. http://pminmo.com/phpBB2/viewforum.php?f=2 PMinMO has answered a lot of questions there. |
| Well. The R4,R5 and the other that are in the same position for the other 2 axises are calculated by the given formula. The 5 resistors in parallel are setting the current, individually for each axis. I have built that board and it is working nice. Current limiting resistor formula is in the top left corner, fist column is the ideal resistance (calculated parallel) and the 2nd column is the current output. For currents above 3A u must use 5 watt resistors, ircc. |
| Ok I etched my board and have the jumper and IC sockets soldered on, just waiting on some parts now. First time etching a pcb for me. I have to say that was pretty cool much easier than i thought it would be. I would like to run the kelinginc steppers p/n kl340h280-48-8a 3.2v 4.5a Will this board hold up ok to them? |
| HobbyCNC Pro Board went "South"! FYI | kreutz | Hobbycnc (Products) | 24 | 06-20-2007 10:34 PM |
| "BRAKE BOARD" NEW Design for MACH3 | Chivo | General Electronics Discussion | 1 | 04-08-2007 12:01 PM |
| How is the "New Hobbycnc" board working? | Ron111 | Hobbycnc (Products) | 35 | 12-23-2006 11:35 AM |
| HobbyCNC Pro Board went "South"! | jhowelb | Hobbycnc (Products) | 36 | 10-18-2006 02:00 PM |
| "Services For-Hire/Wanted" message board | samualt | Forum Questions or Problems | 4 | 03-16-2004 08:29 PM |
