Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 12-23-2004, 04:14 AM
TinkerDJ is on a distinguished road
Open source Eagle pcb files
Has anyone made eagle files of the open source stepper drivers. Just curious.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!Share on Facebook
Old 12-23-2004, 08:07 AM
pminmo's Avatar
pminmo is on a distinguished road
Are you referring to these?
http://webpages.charter.net/pminmo/cncelectronics.htm
If so they were all developed in Eagle Free version.
Phil
Old 12-23-2004, 04:36 PM
Yeah those are the designs but what i was wundering can the eagle drawings be posted as well. I'm just getting my second pcb mill built. First one was less then usuable but it was a good start. This next one should be able to router pcb's. I am just learning to use eagle, its a great program. I have several issues in that the driver board i have is based on the cw tech ucn5804b board. What i would like to do is mill the pcb's for some of your better designs. Then upgrade the driver boards.
Or do you think it is worth my time to try and work the schematics out and then get boards from eagle on my own? Or would that be more then something a beginner can do?
I'm pretty much just starting to learn to use all this stuff. I have done the toner transfer method before, but i would like to have the mill do the work. In the end i would like to learn and use pic microcontrollers and this seems like a good place to start.
What boards do you recommend? I noticed that the 3977 is an internally chopped board. As well as the l297/8 boards. Or would tachus42 design be better?
Any info is greatly appreciated.
Old 12-23-2004, 04:53 PM
pminmo's Avatar
I originally had the eagle files on the website but ran out of room. A zip file containing the eagle schematic and board files for the 5804 is attached. Each board has it's merits. The 5804 is the simplest with half stepping and that is it's stong point, the discrete will drive the most current and is simple. If you want one of the other boards just post and I'll attach em. The only exception is the 3977 board, I'm a little more judicious with that one because of the level of difficulty. Before your start down the pic route, look at AVR's by Atmel. www.atmel.com Very popular, cheap, easy to get, some free tools including a free basic complier for less than 2K of code, easy to program. Do a google search on avr and you'll see there is a ton of info out there on them. The go as small as an 8 pin package to very BIG. On board 10bit adc's on many of them, all esquared and flash memory.
Phil
Old 12-23-2004, 07:13 PM
Thanx for the file. I have more then a dozen pic's from their free samples. That and i have a book for them. I am interested in avr's as well, i'll have to do some more looking around. But besides that i still wont to be able to mill my own pcb's. I just finished my new mill today. Now i have to connect the bigger motors and then start figuring out were i'm going to put my limit and home switches. Thanx again Phil.
Old 12-24-2004, 12:02 PM
pminmo's Avatar
Attached is the eagle files for Tachus42's 3 axis discrete board and 3 axis chopper.
Old 12-24-2004, 12:05 PM
pminmo's Avatar
Attached is the eagle files for the 4 axis interface board:
Old 12-24-2004, 12:09 PM
pminmo's Avatar
Eagle files and word document on the single axis discrete driver.
Old 12-24-2004, 12:12 PM
pminmo's Avatar
singe channel L297-l298 eagle files:
Old 12-25-2004, 02:58 AM
Thanx for the christmas presents Phil. Have a merry christmas and a great new year.
  #11   Ban this user!
Old 03-22-2005, 08:02 PM
Ito-Brazil is on a distinguished road
WOW, That´s called OPEN SOURCE !!!!! Wonderworld !!!!!
Long life to PHILL and CNCZONE !
  #12   Ban this user!
Old 09-22-2005, 07:18 AM
pcroxford is on a distinguished road
I've hit the open source driver goldmine!!!! Thanks for sharing. The world is a better place now.
PIC Open source Servo Driver Schematics development? Rossz Open Source Controller Boards 90 10-26-2011 04:37 PM
Any ideas for open source CAM package? galacticroot OpenSource Software 26 10-22-2007 12:35 PM
Open Source CNC Controller Specification gregmary DIY-CNC Router Table Machines 28 12-04-2005 10:58 PM
What's in work at the open source pminmo Open Source Controller Boards 0 02-13-2005 02:55 PM
Open source driver designs pminmo General Electronics Discussion 0 05-05-2004 10:29 AM
