Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 02-28-2009, 08:15 AM
MaX-MoD is on a distinguished road
YAPSC:10V : The glue between Step/dir and +/-10V servo amp
Hello everybody,
Got a nice industrial servo amp taking analog command, and want to use it with MACH3 ou EMC2 with STEP/DIR? You are at the right place!
Yesterday I successfully tested my first proto of YAPSC:10V. Whereas it still lack some documentation it is ready for production, I am getting pro made PCBs and components order soon.
This board is based on a dsPIC30F4012, and uses a modified code from Lawrence Glaister's dspicservo.
On top of that, it is Open Source (GPL) so you can modify it to your needs!
FEATURES :
  • Takes position feedback from quadrature encoder on the servo (resolvers cannot be used directly but some amps can output quadrature signals from the resolver feedback)
  • Compatible with both torque and speed controlled amps
  • Takes STEP/DIR command from PC
  • ENABLE signal from PC can disable the amp
  • Output amplitude can be selected from +/-0V to +/-10V, to feed +/-10V or +/-5V amps
  • Jumper selected TTL or differential quadrature encoder input
  • FAULT input from the servo amp
  • Reset/ENABLE output to the servo amp
  • One additional input for future use
  • Programmable max error limit : 0 (disabled) to 32768
  • PID tuning program for linux, windows (and probably Mac OS) : YTT (under development)
  • STEP/DIR input multiplier (allows faster speed)
  • 1MHz max step and encoder rate!
  • etc.
NOTE: There is NO power stage on this controller! It is specially designed to control those industrial speed or torque drivers.
CODE, SCHEMATICS AND PCB :
here (3.6MB file)
PICTURES :
3D view from KICAD
PCB
first proto in test
VIDEO :
This is a sneak preview to show how fast and accurate it actually is. The servo is a 0.5KW (~3/4hp) 3 phases servo from Seidel driven by a Digifas 7200 and YAPSC:10V. It's quite impressive knowing it goes from 0 to 2000 rpm in less than 0.3 seconds!
STEP/DIR input is from EMC
NOTE (legal part):
You can compile the dsPIC's firmware with the free student version of MPLAB C30 compiler. In that case, any other use than research/study is strictly forbidden (limitation due the compiler's student licence).
Yet zip contains the project compiled with a full licence of MPLAC C30 compiler so the only limitations is from the GPL licence (read included gpl-3.0-standalone.html for more infos)
I will take no responsability in case of personal injuries or material damages! This project comes without any warranty and support! ...altough I will be pleased to answer you questions
That's all folks!
Old 02-28-2009, 11:28 AM
keebler303 is on a distinguished road
MaX-MoD
Looks great. Please let us know when you have the chance to get an english manual written, my French isn't quite up to the task.
Matt
Old 02-28-2009, 02:06 PM
A.A A.A is offline
A.A is on a distinguished road
Power Stage
What about the power stage of this controller ? if some one is not having a nice industrial servo amp.
Old 03-01-2009, 03:07 AM
I am translating the manual to English in my free times, so it cannot go very fast...
A.A, this board has no power stage, it is specially designed to control those analog input industrial drivers.
But I have another project, YAPSC:V2, wich will include power stage.
Old 03-01-2009, 03:57 AM
jalessi's Avatar
jalessi is on a distinguished road
Question
MaX,
I have some brand new Sanyo Denki BL Super PV 30 amp drives.
Model PV1A030SGDNP50
http://www.motiononline.com/PDF%20Fi...COS_Manual.pdf
I beleive it is a either Devicenet "CAN" or Sercos Interface.
Do you think you could adapt your interface so these drives would be able to take Step and Direction commands?
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 03-01-2009, 06:09 AM
Jeff, I fear SERCOS interface is a lot more complicated that analog output. I should be able to do it but the problem is that it will take me so much time I cannot afford...
I don't know if regular PC's UART (com port) are physically adapted for SERCOS link, but maybe the easier thing to do is to write a HAL driver for EMC that would output SERCOS commands on the serial port (or maybe on a fiber optic Ethernet card), because it seems that SERCOS takes directly velocity&position commands.
Or maybe the IDN80 "torque command value" is enough to control the amp...
In that case, maybe a simple fiber optic transmitter linked to YAPSC:10V and a some modification to the code could be enough?
But SERCOS technical description isn't free nor easy... good luck
Regards,
Max
Old 03-01-2009, 09:39 AM
Max
I ran your french manual through google page translator and it does a decent job. Maybe that would save you some time on getting the english version done. It may be more trouble than its worth as there is a lot of literal translation which is not correct. There is a lot of talk about food for the MOSFETs.
Keep up the good work
Matt
Old 03-01-2009, 04:07 PM
tecfacet is on a distinguished road
hello max ...
are boards available? i would like to get a few to test.
i also would like to build a step/direction servo power amp.
please contact me at tecfacet@yahoo. com
take care.
roger
Old 03-01-2009, 10:51 PM
nhatson.elec is on a distinguished road
Dir Max
about jumper P7, P8, P9 . when it need conect to 2,5V?
your encoder interface can direct connect to ac servomotor encoder? (replace for 26ls32 chip?)
thanks
regards
Old 03-02-2009, 05:41 AM
P7-9 should be placed for single-ended TTL encoders; otherwise the input is similar to 26ls32 chips : Differential line
More infos in the upcoming manuel.
  #11   Ban this user!
Old 03-02-2009, 06:56 AM
mactec54 is on a distinguished road
Hi MaX-MoD
A much needed Glue as you put it Step/Dir to Analog good job
Get it all finished MaX before doing any changes for anybody or it will never get done I have seen many come & go because the requests for change over take the main unit to get done
So guys let him get it out Here in the market place before you request change for your needs
Mactec54
  #12   Ban this user!
Old 03-02-2009, 08:57 AM
KCrouch is on a distinguished road
Some missing files
I downloaded the zip file and tried to open the schematic. There is a message that says that the following files can't be found. They are missing from the zip.
optocoupler-2.lib
linear4.lib
cap-vishay-153clv.lib
ref-packages.lib
HD15_B.lib
connect.lib
Can You add them to the zip or send them to me at kcrouch@comcast.net please.
Thanks,
Kenny
Gecko PID step motor servo Mariss Freimanis Gecko Drives 109 10-23-2011 04:47 PM
Servo step multiplier JerryFlyGuy Servo Motors and Drives 8 05-15-2007 02:20 PM
Units Per Step For Servo bgolash Mach Software (ArtSoft software) 1 02-14-2006 01:46 PM
Servo and Step motors Dre361224 General Electronics Discussion 2 06-08-2005 08:33 PM
stepper, half step, servo?? which to get? blazer928 General Electronics Discussion 4 04-13-2005 12:28 PM
