Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 01-19-2009, 12:04 AM
amplexus is on a distinguished road
higher current h-bridge l297/l298
I'm looking for an easy way to boost the output of the l297/l298 chipset from a max of 3 amps bridged to 8 amps or so. Is there a way ro hang some mosfets off the l298 h-bridge to up the power or is there a higher current h-bridge that is compatable with the l297.
Amplexus
Old 01-19-2009, 03:49 AM
michaelaneccent is on a distinguished road
the 297/98 combo. you can remove the 298 and use a 74aco8 and 4 FET,s have a look at
www.pchilton.co.uk/images/stepperdriver.jpg I have used IRF50N06 plus FR304 diodes
he used IRL640 as it is a 200 volt device with out diodes. i have read of people using two
298 in parallel but this is still not enough for what you want to do.
Hope this may help, Michael an eccentric English man.
P.S. or a 74HC08
Old 01-20-2009, 08:43 PM
Thanks,
This seems to be workable or at the very least a great start on a design. I'll knock together a prorotype and see how it works.
Amplexus
Help pls L297/L298 board problem crazydaddy Open Source Controller Boards 5 09-10-2011 10:44 AM
Troubles with L297/L298 ragrillo Open Source Controller Boards 43 10-21-2010 08:10 AM
Need Help!- l297/l298 with mach3 manmardam Mach Mill 6 02-01-2009 05:56 AM
L298/L297 contoller need help sixpence General Electronics Discussion 4 04-29-2007 09:11 AM
Clarification on using PWM with L297/L298 adroitguy General Electronics Discussion 2 01-20-2006 12:37 AM
