Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
  #37   Ban this user!
Old 08-19-2007, 03:50 PM
h_bernard is on a distinguished road
hello,
thank you, i going buy a ocsioscope for looking the signal output.
  #38   Ban this user!
Old 08-23-2007, 04:16 PM
hello,
thank phil.
have resolve the problem it s a bad solde of U1
good day
  #39   Ban this user!
Old 10-31-2009, 11:14 PM
nofx is on a distinguished road
Matching motor to controller
I'm looking at building the first version of the controller build on the Allegro 3977 IC. I have a few questions but before I get to those. My background is that I'm in school for Millwright. So the electronics I understand but not quite so hopefully someone with far greater knowledge will be able to answer my questions.
The controller board link is http://pminmo.com/ss3977/ss3977.htm
I'm looking at the following motors on ebay.
http://cgi.ebay.com/BRAND-NEW-Vexta-PK266-02A
It has 1.4amp at 5vdc for bipolar series. Will it work with that controller?
What is the PFD mean on the controller instructions mean its near the reference pin to set the amps for the motor?
thank you jon
  #40   Ban this user!
Old 12-17-2009, 04:43 AM
synchron is on a distinguished road
hi there,
I'm new to the forums, i've searched a lot in the forums and i couldn't find anything related. I want to ask if trip current of the motor can be changed with a3977 ic on the fly. I want to use this card with a simple modification, i will connect a digital potentiometer and i want to raise the motor to the peak current whenever it will rotate. Else i want to lower the current for not to heat the motor excessively but also obtain a slight braking from the motor. If anybody tried to change the trip current on the fly please let me know.
  #41   Ban this user!
Old 12-17-2009, 04:50 PM
pminmo's Avatar
pminmo is on a distinguished road
Originally Posted by synchron View Post
hi there,
You can modify Vref to alter motor current. I can't say I would recommend doing it while the motor is actually rotating though.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #42   Ban this user!
Old 01-28-2010, 11:23 AM
Digital Pot Worked Fine but what is that noise???
I've finally constructed my prototype model and now I am experimenting on it. As I mentioned before I was planning to set the current with a digital potentiometer and that also worked fine but there is only a single problem, at idle state motor creates very high pitched weird sounds in every single mode(full, half, 4x, 8x). First I thought maybe digital pot gives an oscillating output and I got rid of it and placed a good old trim-pot with 0.1uF decoupling capacitor at its output. But again these sounds continued, then I tried to measure what is going on with oscilloscope placing the probe on sense connection of the IC (since it is the sense port of chopper circuit where you can see the actual waveform). And the results are interesting, in idle mode there are lots of pikes and while rotating there is something going on in microstepping modes but I would not say that a sinusoidal. I am thinking of PWM timer R, C values might not suit my motor. Any other ideas?. By the way I am using a Lin Engineering 5718M-02S 24V 2.1A motor.
  #43   Ban this user!
Old 01-28-2010, 11:31 AM
I nearly forgot. I thought that this IC has the capability of 2.5A per phase but now I am only seeing max 1.0A. Did I read the datasheet wrongly?
  #44   Ban this user!
Old 01-28-2010, 06:05 PM
pminmo's Avatar
Your hearing the frequencies of the choppers running, its normal. You can tweak the rc1 and rc2 values to help with certain motors. With a machine actually running and cutting, you don't hear them. If the machine is paused for long periods of time, the motors should be disabled anyway for safety.
You can't measure the current with normal test equipment.
  #45   Ban this user!
Old 01-29-2010, 01:58 AM
Thanks for the chopper advice. I tried with 640pF, 1000pF caps with 20Kohm, 30Kohm, 50Kohm, 100Kohm resistors in all combinations but I still hear buzzes with varying frequencies depending on at which microstep level the motor is stopped. If I am hearing frequencies; what should I do, lower RC multiplication or increase? In data sheet it is stated as to set RC multip. to determine fixed off time, and I think ic changes on time and induces PWM current control on the motor so chopper frequency is changing at all times with the formulation fpwm=1/(ton+toff). I think thats why I could not set an appropriate RC multip. for my motor. On the other hand, how should I set C to obtain a proper blanking time.
  #46   Ban this user!
Old 01-29-2010, 08:16 AM
pminmo's Avatar
You can't get rid of the noise.
  #47   Ban this user!
Old 11-03-2011, 01:02 PM
pminmo's Avatar
Originally Posted by Yu Min View Post
Maybe is A3977 not fitable for your motor?
Someone recommend a new chip THB6064AH to our company.I have looked through the datasheet from google http://www.hhbytech.com/Admin/Media/...445_588784.pdf .It sounds much better than A3977.
Hope it's useful for you.
In general, most monolythic stepper ICs will generate spurious motor noise when setting idle. It's the current control oscillators of the choppers.
As to the Toshiba parts, they have the same tendancy, although not quite as bad as the 3977.
I'm always amused at the noise issue, you never hear the noise over a running spindle motor. When idle the motors should be disabled for safety reasons, thus it's a non issue unless your using a laser.
New board help requested pminmo Open Source Controller Boards 32 09-30-2008 05:10 AM
single sided A3977 board ( got files uploaded ) tekno Open Source Controller Boards 170 01-27-2007 07:30 PM
New and need your help Please (driver board) Oldmanandhistoy General Electronics Discussion 17 06-12-2005 04:48 PM
where to buy or make G201 breakout board ? best price ? Calico Gecko Drives 9 06-11-2005 10:00 AM
Is possible to create my own step board? samsagaz General Electronics Discussion 2 03-28-2005 03:24 PM
