Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 11-12-2004, 01:56 PM
OCNC is on a distinguished road
2x5 pin headers-why?
I've noticed that in the unipolar control board and the 3 & 4 axis BOB you're using 2x5 header pins for connections. Since only 3 lines are actually being used why a 2x5 header? Why not just 1x3? Also why did you bring out pins 1 and 9 to a solder pad? Is there some future use in mind regarding these choices?
Thanks!
Chris
Old 11-12-2004, 05:22 PM
pminmo's Avatar
pminmo is on a distinguished road
Several reasons.
1. A ground inerspersed with a signal is less prone to noise and adjacent signal coupling.
2.10 pin IDC connectors and cable are more easy to come by.
3. If you don't want to use IDC cable and headers you only wire discretely what you want.
4. You have the flexability to share one 5VDC regulator.
5. 5VDC might be needed to support opto isolation.
Regarding pins 1 and 9. Two of the boards, the 3977 and L297-8 use pin 1 for enable. The pad gives the flexability to wire as you see fit. Pin 9 can be arranged to give or get 5vdc to those boards also as well as the discrete unipolar.
Phil
Old 11-12-2004, 07:17 PM
Originally Posted by pminmo
Several reasons.
Phil
Would it work equally well to use shielded cable with a dedicated ground wire as well as a grounded shield drain wire?
Thanks again!
Chris
Old 11-12-2004, 08:35 PM
pminmo's Avatar
Thanks again!
Chris
Yes, probably even a little better, simply use the adjacent gnd pin. All the even pins are wired to ground.
Phil
Staggering motors viktorcnc Stepper Motors and Drives 12 10-12-2005 05:56 AM
Sourcing Hardware (1/8 Pin with threads) Swami General Metalwork Discussion 4 03-26-2005 11:35 AM
Troubleshooting the Simple BreakOutBoard and L297 driver pigifly Open Source Controller Boards 38 11-10-2004 03:13 PM
DB25I/O and software pminmo General Electronics Discussion 4 08-13-2004 09:27 AM
Pc Rs232 > Fanic 10te-f abselect General Electronics Discussion 0 07-06-2004 10:23 AM
