Page 2 of 23 FirstFirst 1234512 ... LastLast
Results 13 to 24 of 269
Thread: TB6560HQ-Stepping Motor Driver IC 3.5amp
  1. #13
    Mar 2009
    Good evening,
    Lucas i have a question about your schematic, R7,8,9 are look to have a value of RES2, how do you determine the value of the resitors?
    Good job on your PCB by the way.
    Thanks for your help Dan
  2. #14
    Jan 2005
    Belgium
    Dan,
    thats not my schematic.
    Attached is the one I am using on 2 machines (ver 1).
    I have the optocouplers on the BOB.
    Regards,
    Luc.
    Attached Files Attached Files
  3. #15
    ggg
    ggg is offline
    Registered ggg's Avatar
    Jul 2005
    Argentina
    Quote Originally Posted by lucas View Post
    I just replaced them with the "non hissing ones" without changing anything else and it's dead silent.
    So I need to find non-inductive ones, a quich search at different suppliers wasn't succesfull, they are either too big (3W) or SMD ones wich are just underrated.
    Anyone knows a good supplier?
    Could any body tell me if there is any possibilitie to add any type of Vref in orther not to chage the 2 Rsences any time I want to use diferent motor current ? As have Allegro (sanken) or ST Ic's.Like PIN 10 in TA8435HQ
    _____________________________________________
    [COLOR=DarkOrange]Hare Krishna Hare Rama[/COLOR]
  4. #16
    ggg
    ggg is offline
    Jul 2005
    Argentina
    IC vref
    Could anyone tell me if there is any possibilities to add any type of Vref in order not to change the 2 Rsences any time I want to use different motor current ? As have A3986, L297 or TA8435HQ ( PIN 10 ) IC's
  • #17
    Jan 2005
    Belgium
    Sorry for the late reply.
    The absence of a Vref input is indeed a disadvantage for this chip.
    It's very big advantage is the price: 4.2 US$ for a 1/16th microstepping chip at digikey.com.
    But you can use the 2 torque inputs to reduce the current output.
    I didn't have issues with this, the drivers were build to match the motors when building a machine, if stronger motors are needed after tests then indeed the resistors have to be altered, however this is quite easy compared to the motor change, mechanical changes, bigger power supply etc...
    One option isn't possible: one driver cabinet for different machines like you can do with Gecko's where the current resistor is incorporated in the motor cables.
  • #18
    Registered pminmo's Avatar
    Jun 2003
    St. Peters, Mo USA
    The TBQ6560 is a nice little chip, I've been pleased with how it performs. Yes it suffers from being less flexible on setting currents. One point I would make, it's very important to use a low esr capacitor on VM, and a decoupling capacitor very close to the chip for VM supply pins.
    Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
    Vist my websites - http://pminmo.com & http://millpcbs.com
  • #19
    Jan 2005
    Belgium
    Phil,
    do you have pictures of your design using this chip?
    PCB layout for this one isn't really easy.
    I have used SMD (low inductive) current sense resistors on my latest build and the motors are dead silent. They are 0.5 ohms each and the pcb has 3 locations for each coil, so installing one resistor gives a 1 Amp drive, 3 makes a 3 amp drive.
    Regards,
    Luc.
  • #20
    Jun 2003
    St. Peters, Mo USA
    Here is one version. Sense resistors are on the bottom of the pcb. SMD 2515 2W.
    Attached Images Attached Images
  • #21
    Jun 2003
    St. Peters, Mo USA
    The other:
  • #22
    Jan 2005
    Belgium
    Very nice.
    I like the plugin type of the Naos. Looks like a G250/G540 style of setup.
    At what voltages and currents have you tested these chips?
    Did you also "intentionally" forgot the power-up and down sequence mentioned in the datasheet?
    Nice work.
    Regards,
    Luc.
    PS: I still should have a bunch of soldercup DB25's left over from my mini and mainframe computer service time ages ago, these can be mounted easily with the PCB between the pins.
    So you gave me a new idea for an easy configuration...
  • #23
    Jun 2003
    St. Peters, Mo USA
    Yes I did intentionally skip the "recommended" sequencing, kind of, Enable and reset are sequenced. Since there is no timing spec on the Vdd to VMA sequence, I decided to build it and see if there are any issues. So far no problems.
  • #24
    Registered jalessi's Avatar
    Feb 2007
    U.S.A.
    Question
    Phil,
    Do you sell any of these as kits?
    How is the performance?
    Any Video?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  • Page 2 of 23 FirstFirst 1234512 ... LastLast
    LinkBacks (?)
    1. TB6560HQ microstepping stepper driver chip
      By lucas in forum Stepper Motors and Drives
      Last Post: 01-18-2010, 04:26 PM
    2. Keling stepping driver
      By Mongkol in forum Automation Technology Products
      Last Post: 05-13-2008, 02:51 PM
    3. 80V 6A Micro stepping Motor driver
      By eded59 in forum Stepper Motors and Drives
      Last Post: 07-30-2007, 10:43 PM
    4. What is A MUST features for modern stepping motor driver?
      By mugabe in forum Stepper Motors and Drives
      Last Post: 01-18-2007, 07:31 PM
    5. Newbie looking for stepping motor and driver advice
      By maquiza in forum Stepper Motors and Drives
      Last Post: 09-06-2006, 07:08 PM
