Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 08-31-2008, 11:11 AM
xinzc28 is on a distinguished road
need help on sense resistor
My friend gave me a stepper, bipolar rated at 5.3V 8.5ohm (0.625A / phase)
I use AVR + ST L6219 for controller http://www.st.com/stonline/products/...re/ds/1377.pdf
I have 0.22ohm 1w resistor then set vref to 1.65v since the formula from datasheet to calculate max current is
I max = Vref /RS * 10
= 1.65 / 0.22 * 10
= 0.75A -> a little bit over current
then I measure the voltage at RS, it 0.12v
I=V/R
= 0.12 / 0.22
= 0.64A
Am I on the right track here?
Is it normal for 0.625A stepper drived by 0.75A controller drain 0.64A ?
Old 08-31-2008, 02:46 PM
irving2008 is on a distinguished road
= 1.65 / 0.22 * 10
I=V/R
= 0.12 / 0.22
= 0.64A
The current in the coils is not DC but PWM'd to create the necessary varying drive level to step the motor. Therefore the voltage you measure will be an average voltage (roughly, depending on your meter) but not either the peak or true RMS voltage, (and therefore current) - in other words measuring the sense voltage tells you little about the actual current as its not a static value (except maybe when the motor is stationary). However its clearly in the right ballpark so unless your motor is getting excessively hot I'd be happy with it... but why not set Vref to 1.375v, or chage Rs to 0.27ohm?
Old 09-01-2008, 07:33 AM
Thank you for your comment & advice.
I'll change vref to 1.375v.
since there is no problem I'll rebuild the circuit from breadboard to pcb.
Finally, Soft Jaws that Make Sense Team Pierson Product Announcements & Manufacturer News 0 04-28-2008 08:24 PM
no sense of direction joe kilo Mach Software (ArtSoft software) 1 03-31-2008 09:25 PM
Lead on California, even if it makes no sense dynosor Environmental & Alternate Energy 8 11-03-2007 09:37 PM
Does this make sense?? Dman DIY-CNC Router Table Machines 9 12-29-2005 12:28 AM
Help choosing sense resistor for H bridge Codeman General Electronics Discussion 12 08-17-2005 12:02 AM
