| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
hello all, in search of a best and tough bi-polar stepper driver ,i ended up at reprap's stepper controller.they built it for rapid-prototyping machine.but as it accepts pulse and direction commands i guess it can be used for CNC too. http://www.reprap.org/bin/view/Main/...tor_Driver_1_1 the point that why i got impressed with this board is,bcz it accepts inputs of max and min travel from the limit switches.this saves my lot of input pins. but befor building it i have some doubts in the schematic.(as iam little dumb at undestanding schematics now and as this forum visited by best CNC experts,iam posting here) 1.the power connector has input for both 5v and 12v.that 12v is ment for stepper.say if my stepper is rated at 24v,then can i connect 24v instead of 12v? 2.i don't understand the purpose of stepper adjust in the schematic at all.what is the TP1 ment for? if it to tune the current of stepper,how can i do it? 3.and what is for the Master and slave pins? 4.can i avoid connections SYNC,SYNC,ENABLE at input side? are they required? please help in understanding these issues. Thanks and Regards |
| The Sync pins are all intended for having multiple axis' chopper drivers all in sync by using a shared clock source. You could probably just set them all as master and ignore the sync. There's a quote further down: "It turns out that you can also just set all your boards to 'Master' and ignore the 'Sync' lines." TP1 looks like a voltage divider to set the current on Vref. Turned one way will give you full current (2A on the 298?), the other way will give you no current (motor won't turn). Adjust it for the highest current that doesn't overheat your motors. Read the section "Current Adjustment" on the page. Google for AN470 APPLICATION NOTE THE L297 STEPPER MOTOR CONTROLLER and the L297 and L298 datasheets for more info. Not sure why you're happy that the board accepts Min/Max inputs...it just passes them from the switch headers pins to the IO signal wires...you still have to hook these wires up to your controller. If it were me and I had limited IO, I'd just hookup all the limit switches as a loop with the switches NC, so if any switch is triggered it breaks the loop and halts the machine. Only needs one input. D. |
| Thanks for the reply. and i was not properly reading the schematic.by looking at the data provided in the site i thought it can take inputs directly.my mistake. and regarding the current adjustment,i have to measure the voltage between the TP1 and ground of the circuit? i found the formula from pminmo site adj= 0.5*rated current of motor.but don't understand the measurement points. |
| Tags |
| reprap, stepper |
| Rapid Prototyping - Fabathome / Reprap - On bridging the gap? | ostranenie | Printing, Scanners, Vinyl cutting and Plotters | 2 | 08-29-2008 09:03 AM |
| reprap project | Doug G | CNCzone Club House | 4 | 05-28-2008 08:07 AM |
| Wanted DIY stepper driver circuit for 6 wire stepper motors | Colin300 | Australia, New Zealand Club house | 5 | 09-20-2007 09:20 PM |
| STEPPER DRIVER FAQ {Stepper/driver amp per phase match. | huios | Stepper Motors and Drives | 0 | 08-27-2006 08:43 AM |
| What stepper driver can I use ? | ccm | Stepper Motors and Drives | 18 | 11-23-2004 10:49 AM |
