Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 04-11-2008, 05:56 PM
cnc2 is on a distinguished road
Question Is this interface compatible with UHU ?
Hi every body on the forum !
I've got a question about this parallel interface http://pminmo.com/4axisopto/4axisDIYopto.htm Is it compatible with the UHU servo driver ? or can you point me on a DIY 4axis optoisolated interface that's working with UHU's ?
Thanks !
cnc2.
Old 05-26-2008, 08:40 PM
LZ1TWB's Avatar
LZ1TWB is on a distinguished road
The UHU controller has built-in opto isolation , so you could wire it directly to your parallel port.
Todor
Old 06-01-2008, 05:55 PM
Todor
Thanks for the reply man !
since i posted,i had some info from kreutz & the guys from the diy open source controller forum & i have built this interface :http://pminmo.com/PMinMOwiki/index.php5?title=5axis
Best regards,
cnc2.
8020 compatible rails? jseiler Linear and Rotary Motion 1 03-05-2007 08:31 AM
gecko compatible dgalaxy Bridgeport and Hardinge Mills 2 06-04-2006 11:28 AM
450 oz Stepper and Gecko 202 compatible? andy_ck87028 Stepper Motors and Drives 2 12-03-2005 09:11 AM
TTL Compatible controller metalhacker Open Source Controller Boards 2 05-23-2005 12:25 AM
Are CAT and BT compatible? ETNOM General Metal Working Machines 2 12-16-2004 07:08 AM
