Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 02-03-2008, 04:33 PM
karl1's Avatar
karl1 is on a distinguished road
Parallel Port on Laptops
I hope I'm not posting something that has already been discussed, but I was looking for some sort of adapter to shift the lower voltage logic (3.3v) of a laptop's parallel port to those needed by (most of the) controller boards out there. I'd even consider a commercial "box' if available. If there isn't an open source, then I would look into building one of my own design, and would post it if there was an interest. Does anyone else have the same problem with the lower voltage interfaces, especially laptops and newer desktops?
Thanks!
Karl
Old 02-03-2008, 04:47 PM
LeeWay's Avatar
LeeWay is on a distinguished road
My Toshiba Satelite didn't have a port. My Thinkpad did, but ran the machine like crap. Possibly due to the low voltage thing. I only used a basic breakout board though. I think some of the Bobs they sell have a feature to increase the voltage and milliamps to useable amounts. I can't confirm that though.
Lee
Old 02-03-2008, 05:01 PM
Greolt is on a distinguished road
Most of the commercially available BOBs will handle 3.3v printer ports.
Have a look at this one as an example.
http://tinyurl.com/2qjbb6
Greg
Old 02-03-2008, 05:12 PM
karl1's Avatar
Thanks for the leads! At least I know I'm chasing down a LVTTL issue; I too am using a Thinkpad. My BOB was one I aquired from PMINMO last year - worked fine until I switched from Desktop to Laptop. I might kludge together an isolated BOB based on one shown in PMINO's website, but using the Fairchild FOD063L as the optoisolator, instead of the HCPL26xx shown. I'll post my results!
Thanks!
Karl
Old 02-05-2008, 10:37 AM
eSilviu is on a distinguished road
Thanks!
Karl
I think this will help you.
With 2 of this IC it's possible to solve completly the problem.
http://www.analog.com/en/prod/0,,768...DG3308,00.html
problem: IC is SMD, and for PCB you will have to use Positiv20 or tonner transfer method.
if you need help with schematic or PCB send-me a mail.
Cheers!
C++, Win XP, Parallel Port Zumba Coding 7 03-29-2012 01:12 PM
Where's the parallel port? cdlenterprises Mastercam 23 01-20-2007 05:23 PM
Second parallel port? essa LinuxCNC (formerly EMC2) 11 04-12-2006 02:18 AM
Parallel port Aldoseri BobCad-Cam 11 03-13-2006 10:10 AM
Parallel Port Shanghyd Computers and Networking 1 11-22-2004 11:56 AM
