Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 02-02-2008, 11:18 AM
stragenmitsuko's Avatar
stragenmitsuko is on a distinguished road
Inhibit vs phase chopping
Could somone explain the adavantages and disadvantages of these two
chopping methods .
Also calles fast vs slow decay if I understand correctly .
The story behind this question .
I'm building , or maybe better I'm trying to build , a 1/4 step driver .
Using a L6506 current controller , a 1 bit DAC , and the well known L298
as a driver . A gal 22V12 will produce the necessary logic .
I kow there are chips out there that will do the job , I just like to design something myself . And using a gal has several other advantages like e-stop and synchronised limitswitches
The problem is that wathever I do , the L6506 goes out of control , and the phase current drops to nearly zero as the voltage is increased beyond .
the maximum allowed stepper voltage .
So I've read that fast decay offers a better current control wich might solve my problem , but also produces a larger ripple .
Secondly , I've seen on some datasheets that an RC chain is put across each stepper winding . Is this a substitute for the clamping diodes , or do they have a different function .
Thx
Patrick
Picture shows a not yet finished prototype .
The basic idea is to use standoffs to mount the pcb on the back of a nema23
Need Help!- DIY Driver, LMV339 chopper, 74HC08 not chopping. vim.au General Electronics Discussion 18 02-08-2008 03:32 AM
Relations between chopping frequency and step pulse rate bunalmis Stepper Motors and Drives 14 05-30-2006 11:37 AM
Cutting/Chopping small aluminum pc's best way? dbtoutfit General Metalwork Discussion 3 03-18-2006 06:28 PM
phase chopping l297+l298 dfv General Electronics Discussion 1 06-16-2005 07:33 PM
Quesion regarding inhibit jumper settings for Fanuc drive cncboy CamSoft Products 1 03-07-2005 05:43 PM
