Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 11-10-2007, 04:08 AM
kwackers is on a distinguished road
Glass scales for UHU quadrature input?
Hi, this is my first post so please be kind...
I've ordered the parts to make the UHU servo controllers and am considering how to fit them to a machine.
Since I was considering fitting the machine with glass scales anyway I was wondering if there was any problem using these to provide the quadrature inputs for the controllers.
Obvious benefit would be positional accuracy since the position would be correct regardless of leadscrew backlash, however since this very backlash would provide 'loose' coupling between the motor and the controller I'm wondering if there are likely to be any feedback issues with this.
In short has anyone done this? Is it likely to work for ballscrews but not for acme threads (due to the increased backlash)?
Any input gratefully received before I spend to much on the wrong things
Steve.
Glass scales as encoders dcprecision General Metal Working Machines 77 01-19-2010 11:51 AM
Converting Anilam to Mach3 - Pixie and Glass Scales czech General Electronics Discussion 4 01-01-2009 03:16 PM
Working out the required length of linear glass scales hotponyshoes General Metalwork Discussion 7 06-24-2008 08:03 AM
Connectors on glass linear scales - interchangable? hotponyshoes General Metalwork Discussion 0 05-17-2007 01:56 AM
Sorce of used linear glass scales / encoders hotponyshoes General Metal Working Machines 2 05-14-2007 01:17 PM
