Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 10-06-2007, 02:06 PM
MagooT is on a distinguished road
Problems with stepper driver (L297 and L6203)
Hello dudes, i have assembled a board using this schematic
http://netikka.net/maggot/bipolar.png
Here's the board layout
http://netikka.net/maggot/bipolar_brd.png
X2-1 is +5v
X2-2 is +15v
X2-3 is GND
X1-1 is DIR
X1-2 is STEP
M1-M4 are the motor outputs
However it doesn't work.
I have measured about every pin using my oscilloscope but the only strange thing i found is that the outputs of the L6203's (pin 1 and pin 3) are high all the time, when i step it slowly (using jog in Mach3) i can see some small flickering around 14-15volt, but i assume it should switch between high and low.
Since i can't find anything wierd on the board, i'm asking if anyone can spot any errors in the schematic or board layout, i have checked the board about 10 times for solder bridges or stuff like that so i don't think that's the problem.
Any ideas what to look for would be nice, since i have no idea what might be wrong with this.
If you need more info just let me know, and sorry for my bad english
Greets
// MaggoT
Old 10-06-2007, 03:00 PM
markcomp77's Avatar
markcomp77 is on a distinguished road
I found one error... look R6 & R7 on your design
R6,R7 need to be connected to GND and sense->L6203[10]
look -> http://forum-cnc.pl/index.php?topic=55.0
markcomp77@forum-cnc.pl
Old 10-06-2007, 03:48 PM
Thanks for your help.
I have fixed the problem now but it still won't run.
Another go with the oscilloscope shows that pin 1 on both 6203's now switch between 0 and 15volts, but pin 3 switches between 0 and 5 volts i can hear a small ticking sound from the motor when im jogging but it doesn't move.
When i measure between GND and motor outputs M1-M4 i just see a blinking line at 10 volts on the oscilloscope.
Old 10-07-2007, 11:23 AM
markcomp77's Avatar
Originally Posted by MagooT View Post
Another go with the oscilloscope shows that pin 1 out1 on both 6203's now switch between 0 and 15volts, but pin 3 out 2 switches between 0 and 5 volts i can hear a small ticking sound from the motor when im jogging but it doesn't move.
out1 and out2 should switch between 0 and Vs
1)
data sheet of l6203 is:
Vs Supply Voltage --> min=12V typical=36V max=48 V
its better to use higher voltage...
power supply - on AC24V trafo (DC output about 32..33V)
2)
use new L6203... and make new tests
make output current measurements... current of winding
Old 10-07-2007, 11:37 AM
I just found the problem (embarassing) if you look at my schematic OUT1, BOOT1 and OUT2, BOOT2 are the wrong way around on the motor outputs, so i switched them and now it seems to work thanks a lot for your help.
Old 10-08-2007, 02:08 PM
markcomp77's Avatar
do you think about...
making of STEP=1/2 better?
to have equal ful step and half steps...
Old 10-08-2007, 05:11 PM
I'm sorry, i don't understand what you mean, i'm not good at reading schematics what does it do?
Old 10-09-2007, 01:45 AM
markcomp77's Avatar
what does it do?
it change Vref (=>output current) for half steps...
because of this => torque of motor on full steps and half steps will be equal
because of this => half steps will be more precise
Old 10-09-2007, 06:25 AM
Ok, thanks.
Another question, i'm trying to run a small motor from a printer (don't have any other specifications for it other than "10 ohms", unfortunatley), and it get REALLY hot just after a few seconds, so i assume i must recalculate sense-resistors or something? Because the chopper isn't lowering the current at all, can anybody explain how to do this?
Old 10-09-2007, 01:09 PM
markcomp77's Avatar
Ok, thanks.
yes...
but better is to regulate Vref of L297
look there -> R23
use potentiometer (R23) to set Vref
look on any L297/8 driver - make the same...
  #11   Ban this user!
Old 10-09-2007, 01:58 PM
Thanks, i googled around a bit and read about vref, this is what i came up with:
Schematic: http://i20.tinypic.com/2emdkx0.png
PCB: http://i23.tinypic.com/28lg9c8.png
This allows me to adjust Vref between 0 and 1.7 volts, should work great.
Guess it's time to etch a new board an try it out
  #12   Ban this user!
Old 11-11-2008, 08:49 AM
xinzc28 is on a distinguished road
Hi Magoot, I made similar driver.
My 10 ohm resistor is always get to smoke because of excess heat.
Do you have this problem?
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
L298, L297 Stepper Driver abbe Open Source Controller Boards 20 01-13-2012 11:45 AM
CONTROLADORA BIPOLAR CON EL L6203 -l297 lupi200 Spanish CNCzone 13 11-20-2011 08:39 PM
l297 7amp unipolar driver ljd10 Open Source Controller Boards 13 10-09-2007 07:56 PM
L297 / L298n problems - whining motor! bigal Stepper Motors and Drives 2 07-21-2005 04:32 AM
Troubleshooting the Simple BreakOutBoard and L297 driver pigifly Open Source Controller Boards 38 11-10-2004 02:13 PM
