Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 09-24-2007, 02:01 AM
Jakubik is on a distinguished road
engine for UHU?
Will this work with UHU?
U ... 50V
I ... 7,5A
3000 turns/ min.
600W
Encoder with 500 lines will be mounted.
Old 09-24-2007, 05:50 AM
Anfänger is on a distinguished road
Hello Jakubik!
Yes this will work with UHU, but you need a good Cooling for the Mosfets. 7.5 Ampere are too much for a standard Cooling.
My Maschine run with 48 Volt, max 7.5 Ampere Input and encoder with 500 lines faultlessly.
Greatings
Anton
Edit: Excause me my bad English. I am coming from Austria.
Old 09-24-2007, 10:16 AM
Originally Posted by Anfänger View Post
Hello Jakubik!
Greatings
Anton
Hello Anton,
I have similar cooler, additionally with fan. Mosfets are IRFP260N and I´m already running with it engine on enclosed photo (in X and Y axis). But they have only 1000 rpm, the new one has 3000 rpm. Isn´t it too much for servo?
Jan
Old 09-24-2007, 11:28 AM
Originally Posted by Jakubik View Post
Hello Anton,
Jan
Hallo Jan!
You have no problems with the UHU and your servomotor.
3000 rpm x 500 lines = 1 500 000 signals/min
1 500 000 : 60 (sec) = 25000 signals/sec
The UHU controller can cool 200 000 impuls/sec
Greatings
Anton
Old 09-24-2007, 11:14 PM
ejkoeze is on a distinguished road
Slight calculation error. 500 lines are read 4 fold. This means 2000 steps with a 500 cpr encoder. Also 100000 steps per second.
Mach can only output about half. so you'll need the step multiplier (built into the UHU)
Erik Jan
What goes down, should come up.
Old 09-25-2007, 12:52 AM
Hallo!
That's right, but you can set the Uhu from four to two signals.
Now, we have 50 000 signals. Mach can 100 000.
Greetings
Anton
Old 09-25-2007, 01:28 AM
Hallo!
Greetings
Anton
Dear Anton,
how can you change signals from encoder? For example encoder with 500 lines gives 2000 impulses per revolution, am I right?
Jan
Old 09-25-2007, 04:04 AM
Dear Anton,
Jan
Hallo Jan!
That's right.
You can change the impulses with the terminalprogram "UHU Exe". The signals will be halved.
Greetings
Anton
Old 10-02-2007, 08:37 PM
contactirfu is on a distinguished road
Hello Jakubik!
Greatings
Anton
Hi Anton,
I am planning to run my motors at 110V 7.5 Ampere! what should I use. . think water cooling.
I think the peak current is rarely utilized, however have you observed overheating of your heatsink while working?, what other problems have you come across?
Can we have a picture of your control box?
RGDS
IRfan
Old 10-08-2007, 04:10 AM
Unhappy
Hallo Jan!
Greatings
Anton
Hello all,
I have received this engine on Friday, mounted encoder (HEDS5500 with 500 lines) and tested. Strange is, that Mosfets are getting warm but not hot, but engine is getting really hot, even if it is not moving.
  #11   Ban this user!
Old 10-10-2007, 08:23 AM
pastera is on a distinguished road
If your motor is rated at 50V and your power supply should be only slightly higher to make up for controller losses. With the 110 volt supply, the drive will be outputting very narrow pulse widths, increasing EMI and losses (heat) in the windings.
You can add inductors in series with the motor but would not be the best way to fix the heat issue. The correct way would be to lower the supply voltage.
Try running the motor at rated RPM without a load to see if it still heats up - this will increase the pulse width to overcome the BEMF and lower the losses dramatically. If this fixes the heat issue then power supply volatge is definately the root cause.
Aaron
  #12   Ban this user!
Old 10-10-2007, 08:47 AM
Aaron
Hi Aron,
My motors are rated at110v and not 50 v, i am observing heat in theRLC circuit (snubbers) , onlythat i am waiting for the circuit development by Kreutz.
RGDS
Irfan
1st Steam/Air Engine rcazwillis Steam Engines 28 11-09-2009 04:27 PM
Which engine for beginners? joe 3 I.C. Engines 20 07-21-2007 07:49 PM
A good First Engine. mutionu Steam Engines 5 03-01-2007 05:09 AM
jet engine plains godspeed Jet Engines and Ram Jets 3 04-26-2006 01:52 AM
For you engine enthusiasts ChrisJ I.C. Engines 5 02-25-2005 06:19 PM
