Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 06-26-2007, 10:45 AM
Khalid's Avatar
Khalid is on a distinguished road
My Controller Not Working...help Me Pls
I have purchazed FET-3 dynamo controller card from stepperworld.com but it is not working although i checked all cabling many times. only x-axis motor jitters wheras there is no response from Y and Z axis.
I have read through the manual many times but i have not found any discrepancy in my cabling. I checked all circuit + components through voltage meter and ohmmeter but all found okay.
currently in following pictures i just connected z-axis drive with Hi-torque jumper position. please tell me what i m doing wrong.
Best regards.
Old 06-26-2007, 11:34 AM
GER GER is offline
GER is on a distinguished road
Power Supply Voltage
I can’t make out all of the wiring. I looks like you are using the power resistor. If so, I think the motor power supply should be 12v (Yellow-Black). The controller board will still use 5v (Red-Black).
Old 06-26-2007, 09:53 PM
Khalid's Avatar
Smile
Thank U GER:
Okay.. please tell me if i not use power resistor then the connections shown in pictures, leaving out of power resistor, is right.
I will try 12V supply only to motor with power resistor, Is it safe for the motors/controller board. (I have only one controller board :-( )
Best Regards
Old 06-26-2007, 10:30 PM
Khalid's Avatar
Motor Tag
I am using Following Motor
Old 06-26-2007, 11:58 PM
H500 is on a distinguished road
I have the same motor. You must use a resistor to limit the current to 3 amps, or you will burn out the motor.
Old 06-27-2007, 12:19 AM
Khalid's Avatar
Smile Further information
I am using power resistors of 50watt. and currently supplying +5V both to controller and stepper motor as per instruction manual. Also i m using Pentium-4 power supply.
I think the stepper safe voltage limit is 2.7Volts. Guide me. and Help me.
Old 06-27-2007, 09:33 AM
GER GER is offline
Different Motor
The motors I received from Stepperworld where 6v. If the instructions he sent with your motors state the resistor needs to be used with 5v, ignore my last post. How many wires are coming out of the motor?
Old 06-27-2007, 10:17 AM
GER GER is offline
Black Wire
I think I just found the black wire in the picture. I think it is going to the power resistor. Let me make sure I can see this correctly.
Going to the power resistor:
Red-Yellow-Black-Orange
Controller (Right to Left)
Blue-Green-Brown-White-(Empty)-Wire from resistor
Is this correct?
Old 06-27-2007, 11:10 AM
Khalid's Avatar
Yes GER u have correctly defined the wiring. The black wire is from power resistor. All other are the same as u mentioned.
Old 06-27-2007, 11:49 AM
pminmo's Avatar
pminmo is on a distinguished road
Have you contacted stepperworld for support?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
  #11   Ban this user!
Old 06-27-2007, 01:16 PM
Khalid's Avatar
Yes.. Mr. pminmo THE Great
I contacted stepperworld. they advised some steps that i already taken except one to check the circuit on some other PC. Today i check the circuit on the PC of my freind but with same results.
Again i checked on my computer but at this time the motor run on WAVE DRIVE MODE only.
  #12   Ban this user!
Old 06-27-2007, 01:18 PM
Khalid's Avatar
All three axis run on WAVE DRIVE mode only. They all fail to run on HI TORQUE and Half step
Working with MDF Miguelflores General Material Machining Solutions 9 03-16-2008 04:45 AM
DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller maycom DeskCNC Controller Board 1 06-02-2007 01:33 PM
Eia Iso Not Working honk Mazak, Mitsubishi, Mazatrol 12 08-16-2006 07:17 AM
She was working utengineer04 Bridgeport and Hardinge Mills 1 07-25-2005 09:39 PM
Not working well. ihkim Servo Motors and Drives 3 05-23-2005 05:32 PM
