Page 1 of 2 12 LastLast
Results 1 to 12 of 22
Thread: A simple and cheap current limiter for unipolar motors
    666 is offline
    Aug 2004
    Denmark
    Hi all... After posting my 3 axis pic design i promised to post the design of the current limiting circuit.
    So here it is...
    Hope someone can make use of it. I use it myself and it does the job...
    Regards from Denmark!!!
    666
    Attached Images Attached Images
    Attached Files Attached Files
    Mar 2004
    Iowa, USA
    Very cool! I was hoping that you would finish this and post. I have been looking for a simple way to use larger motors.
    RipperSoftware
    666 is offline
    Aug 2004
    Denmark
    Question
    Erh... Finish it? What´s missing???
    The pinouts are easy:
    1. VCC
    2. Motor1 common
    3. Motor2 common
    4. Motor 3 common
    Calculate the resistor value, assemble the board, and connect the wires.
    If you have any questions i´ll gladly help you.
    Regards...
    666 is offline
    Aug 2004
    Denmark
    Smile
    What size motors do you use???
    I use these... The 342´s...
    http://www.jvl.dk/files/pdf/ld042gb.pdf
    666
    May 2007
    Uk
    Good work
    I'll be using a PWM chopper drive on mine but might just whack one of these in at a slightly (+25%) higher current limit to act as a failsafe in case one of my PWM locks or tries to overdrive the motor.
    666 is offline
    Aug 2004
    Denmark
    Smile
    A PWM is the preferred choice, but sometimes simplicity beats technology...
    May 2007
    Uk
    Simplicity quite often rules lmao.
    I will be combining simplicity for the emergency protection side of things with complexity for the showing off side of things. All it takes is a processor crash with the PWM outputs locked on and you could rapidly burn out an expensive stepper.
    666 is offline
    Aug 2004
    Denmark
    Talking
    Upload some pic´s of your device when it´s finished... Allways exiting to watch other peobles creations...
    Goddspeed and regards from Denmark...
    May 2007
    Uk
    Will do - I've got to sort the machine out first - will not be concentrating on the electronics until the mechanicals are done. If my 26mm forstner bit ever turns up from Ebay (its been almost a week now) I'll be able to get on with my bearing mounts
    I visited Copenhagen on company business a few years ago - drank far too much (very expensive) beer but it was a nice place to visit
    666 is offline
    Aug 2004
    Denmark
    Cool
    I´m working on a cast alu design... At present time i need a small gantry mill. Will come up in another tread... For now i use my 2.1 ton Stanko Mill with MT#5 spindle... Heavy metal... And quite awkward to do PCB´s on!!! ROFL And danish beer rules! Good luck with your design. Looking forward to see your gallery when finished...
    Mar 2004
    Iowa, USA
    Quote Originally Posted by 666 View Post
    1. VCC
    2. Motor1 common
    3. Motor2 common
    4. Motor 3 common
    Regards...
    Sorry, didn't mean to offend you. I confused your thread with DaRy who posted about a similar circuit using LM317.
    Simple unipolar driver with current limiter
    666 is offline
    Aug 2004
    Denmark
    Wink
    HEHE... No problem... Sometimes i forget that i made a board myself, and afterwards assume that everyone knows my projects as well as i do...
    Just glad to help if anything should come up...
    666
  • Page 1 of 2 12 LastLast
    1. Simple unipolar driver with current limiter
      By DaRy in forum Open Source Controller Boards
      Last Post: 12-05-2011, 01:30 PM
    2. Linistepper - cheap unipolar microstepping driver
      By lietuvys in forum Open Source Controller Boards
      Last Post: 12-08-2010, 02:17 PM
    3. Cheap Unipolar LPT Driver, High Amperes
      By Urgundiz in forum General Electronics Discussion
      Last Post: 06-23-2009, 09:45 AM
    4. current per phase, unipolar bipolar
      By Ragnarok in forum Stepper Motors and Drives
      Last Post: 02-22-2006, 10:57 PM
    5. Simple unipolar schematic, opto isolated
      By Konstantin in forum General Electronics Discussion
      Last Post: 03-31-2004, 06:02 AM
