Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 09-17-2006, 07:59 PM
BCwanderer is on a distinguished road
New Allegro Bipolar Stepper Driver A3986
Credit for this link goes to slp_prlzys who posted it to General Electronics Discussion
This is posted to Open Source Controller boards as I hope it will be picked up and developed quickly
Allegro has a new Bipolar Stepper driver chip that drives N-FETs in a bridge configuration.
You can buy them now at Digikey for about $5.00
The chip includes high and low side drivers. - No IR interface chips required.
Look here
http://www.allegromicro.com/sf/3986/index.asp
A3986
Dual Full-Bridge MOSFET Driver with Microstepping Translator
Features
* 2-wire step and direction interface
* Dual full-bridge gate drive for N-channel MOSFETs
* Operation over 12 to 50 V supply voltage range
* Synchronous rectification
* Cross-conduction protection
* Adjustable mixed decay
* Integrated sinusoidal DAC current reference
* Fixed off-time PWM current control
Description
The A3986 is a dual full-bridge gate driver with integrated microstepping translator suitable for driving a wide range of higher power industrial bipolar 2-phase stepper motors (typically 30 to 500 W). Motor power is provided by external N-channel power MOSFETs at supply voltages from 12 to 50 V.
This device contains two sinusoidal DACs that generate the reference voltage for two separate fixed-off-time PWM current controllers. These provide current regulation for external power MOSFET full-bridges.
Motor stepping is controlled by the two-wire step and direction interface, providing complete microstepping control at full-, half-, quarter-, and sixteenth-step resolutions. The fixed-off time regulator has the ability to operate in slow-, mixed-, or fast-decay modes, which results in reduced audible motor noise, increased step accuracy, and reduced power dissipation.
The translator is the key to the easy implementation of this IC. Simply inputting one pulse on the STEP input drives the motor one step (full, half, quarter, or sixteenth depending on the microstep select input). There are no phase-sequence tables, high frequency control lines, or complex interfaces to program. This reduces the need for a complex microcontroller.
The above-supply voltage required for the high-side N-channel MOSFETs is provided by a bootstrap capacitor. Efficiency is enhanced by using synchronous rectification and the power FETs are protected from shoot-through by integrated crossover control and programmable dead time.
In addition to crossover current control, internal circuit protection provides thermal shutdown with hysteresis and undervoltage lockout. Special power-up sequencing is not required.
This component is supplied in an 38-pin TSSOP (package LD). The optional lead (Pb) free package (suffix –T) has 100% matte tin leadframe plating.
Old 09-30-2006, 06:06 PM
Azrael is on a distinguished road
Red face
This is a tough one!!! In a combination with IRF540 brings up to 10A at 50V which is quite enough power even for bigger steppers. Next week I will start prototyping my board. The only thing that is still missing is current limiter to approx. 25-30% when no step signal is detected.
Cheers
Old 09-30-2006, 07:53 PM
pminmo's Avatar
pminmo is on a distinguished road
This is the part I mentioned a earlier in the year I was going to wait for. I've been working a compatable design compatable with the other designs on my website for about 2 weeks. Have the 3986 parts in hand, those tssops are small. Most all smds. Cant see a non soldermasked board as buildable. Layout is a bear!
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 10-01-2006, 12:38 PM
DR-Motion's Avatar
DR-Motion is on a distinguished road
Nice chip, just finished a layout for the first prototype
with room left for a midband resonance compensation
circuit. My plan is to test the driver board separately
and switch in the compensation circuit afterward to save
on prototyping costs.
A hint for the curious... the compensation circuit consists
of a bandpass filter and a voltage controlled pwm 555.
more to follow,Gary
embrace enthusiasm to accomplish the task
Gary Davies... www.durhamrobotics.com
Old 10-02-2006, 01:06 PM
Start of prototype board
Here is an update on a A3986 board
All components are regular thru hole except the A3986 TSSOP
I am gathering parts so my final may change depending on the parts I am able to buy
I use Target layout - I don't have eagle files
Any improvements or ideas appreciated.
FYI
Any other good ideas appreciated
Old 10-02-2006, 02:20 PM
DR-Motion's Avatar
with your placement of the fets... it will be
difficult to use heatsinks.
regards
Old 10-02-2006, 03:20 PM
regards
I have a bag of clip-on heat sinks that slip on the TO220 chips
The clip on heat sinks are very versatile.
I would like to use the back to back FET setup like Gecko but the prototype board was set up the way it is to use the simplest and most direct connection from the Allegro chip and the FETs.
After I get the chip up and running, refinements will follow.
Cheers
Old 10-02-2006, 03:21 PM
pminmo's Avatar
Among others, your FET current paths and sense resistor arrangement is a problem.
Old 10-02-2006, 03:37 PM
Please explain your improvement ideas.
I would like to fix it on paper before I commit it to the boardmaker.
Old 10-02-2006, 06:17 PM
pminmo's Avatar
You have to take into consideration high current paths and where to sense the voltage developed across the sense resistor. Same for grounds, motor supply, clamping........... low impedence signal drives, noise immunity.
Right now I need to finish mine, it's laid out, passes all my rules, just need to spend some time reviewing everything.
  #11   Ban this user!
Old 10-04-2006, 03:07 PM
@DR Motion.
Can you please explain the things about midband resonance compensation, I would be glad.
Cheers
  #12   Ban this user!
Old 10-06-2006, 06:43 AM
markcomp77's Avatar
markcomp77 is on a distinguished road
Here explanation is...
http://www.cnczone.com/forums/showpo...0&postcount=30
Here, starts of my projects
Add something else ?
markcomp77@forum-cnc.pl
