06-16-2006, 05:14 AM
SLA7062M schematic review | | Hi All,
I have done the attached schematic based on what is available on the Data sheet for the SLA7062 as well as what has been mentioned in different posts re addition of snubbers to protect the SLA7062M.
Couple of things that I am concerned about...
1. What should be done with M0
2. Sync has been left high by default as I intend to run the controller in 1/2 step mode (most of the times) is this OK?
I have not worked out the values of the snubbers but looking at the fomulas it should be fairly straight forward. The voltage will be limited to a max of 36V.
Any and all opinions are valued and welcomed.
Thanks all
SMK |
