Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
Old 02-04-2012, 03:42 PM
DjD DjD is offline
DjD is on a distinguished road
Linistepper v2 problem
Hello all. I have problem my stepper goes one direction when LPT cable not in PC. If i put cable to PC stepper stop roatating. Why? What to do? Thanks.
Old 02-05-2012, 06:45 PM
James Newton's Avatar
James Newton is on a distinguished road
First, I don't see how that is a Linistepper v2 problem... it sounds like the driver is running the motor just great.
If you are using the old, old, old version of the 4 axis board, with the pulse circuit attached, then that is exactly caused by the intended operation of the pulse circuit. It is diving the x step pin with a resistor, so the parallel port will overcome the pulse signal when it is plugged in. Remove the resistor R9 and the pulses won't get to the x-step line and it won't rotate when not plugged in.
Or did you mean that it will not move at all (even when commanded by the PC) when the LPT cable is plugged in? In that case, the port setup or wiring is probably the problem.
MUCH more detail required for accurate answer.
James hosts the single best wiki page about steppers for CNC hobbyists on the net:
http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
Old 02-08-2012, 10:30 AM
DjD DjD is offline
Thanks for your reply. I haven't used breakout board. STEP and DIR wires I connected directly to LPT port. When I plug LPT cable I can control stepper motor. Your post help me understand what is going on.
Old 02-08-2012, 03:05 PM
RN1, the 3k3 network resistor should be pulling the step line low when the LPT cable is not connected. Check solder connections or remove the PIC and check for 3.3K Ohms between the step pin and ground.
Old 02-09-2012, 06:46 AM
DjD DjD is offline
I used posix layout.
Old 02-09-2012, 11:00 AM
Ok, so you are NOT using a Linistepper V2 then... you are using a Posix Linistepper which isn't a board layout we sell in the kit. Our version has the pull down resistors which prevent this problem. If you are using the Posix, you need to keep the cable connected or you need to add a pull down resistor of 3.3k ohm between the step line and the ground.
Old 02-17-2012, 05:48 AM
DjD DjD is offline
Sorry I'am write to late. Thanks for your reply, now I fixed this problem and I discover another: I power on linistepper, it is idle and two transistors getting very hot. Why it is hot when I do nothing?
Old 02-17-2012, 11:38 AM
This would be normal for any stepper driver. At any given point, two of the 4 transistors would be on, depending on which step you have stopped at. On the real linistepper, there is a low power hold line that can be engaged to reduce power when holding. I don't know if that was included on the Posix design.
Old 02-17-2012, 02:19 PM
DjD DjD is offline
How to make a low power hold line in posix designed board? Also, what settings use in TuboCNC?
Old 02-17-2012, 05:22 PM
I guess you would want to ask posix and the support forum at TurboCNC.
  #11   Ban this user!
Old 02-18-2012, 02:55 AM
DjD DjD is offline
Okay I ask. Thanks.
  #12   Ban this user!
Old 03-11-2012, 02:49 PM
DjD DjD is offline
Hi James. On posix layout with linistepper v2 firmware I found "enable" pin. Where should I connect it on BOB? How to configure Mach3 to work "enable"? Thanks.
Linistepper in C hazimin PIC Programing / Design 9 01-23-2011 08:34 PM
Need Help!- Linistepper troubleshooting shadesdude Open Source Controller Boards 6 06-29-2009 08:42 AM
FYI Linistepper Experience flyboy1015 DIY-CNC Router Table Machines 6 11-12-2008 03:38 PM
'Lil Linistepper Lathe epineh Mini Lathe 37 02-24-2008 08:03 AM
Linistepper tante Open Source Controller Boards 7 12-19-2005 09:24 AM
