| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
| That kinda depends on what you want to build. I have used many different types of BOB's. From the extremely simple straight pass through to driver dedicated. I am not familiar with the drives. The ultimate drives for me are Gecko's. Simply outstanding drives.
__________________ Lee |
| I agree with LeeWay, we need to know more about what you want to do, and Gecko Drive makes the finest drives... however, if you use the calculator at techref.massmind.org/techref/io/steppers.htm#Estimating and find that you need anything up to about 100 watts of drive power (3 amps, 35 volts) then the Linisteppers will do just fine and will save you quite a bit of money over a Gecko. The Linistepper has a nice 4 axis BOB, with very low cost cabling options: Break Out Board, Logic Power Regulator, Relay Driver, Indicators, Switches, Microchip PIC, LCD Panel, Current and Temp sensors. The complete 4 axis, with a 5 volt supply regulator, ALL the cables for 4 axis drivers and parallel cable to the PC is less than $25. The 4 axis FULL KIT is less than $150 (compare to a Gecko 540; not as much power, but enough for a small mill). A 3 axis FULL KIT (like a Gecko 540 but with just 3 axis instead of 4) is $114.
__________________ James hosts the single best wiki page about steppers for CNC hobbyists on the net: http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o) |
There are several break out boards listed at pminmo.com which are quite good. I personally feel opto-isolation is over rated and causes more trouble than worth. I just use an old PC (better parallel ports anyway) and run turboCNC then do my designing on my nice laptop and sneakernet the files. If something frys, old PC's are a dime a dozen.
| Linistepper in C | hazimin | PIC Programing / Design | 9 | 01-23-2011 08:34 PM |
| Linistepper Help Required | wolverine123 | Stepper Motors and Drives | 5 | 04-04-2010 01:30 AM |
| Chinese Mill + Chinese accesory + Newbee = Problem | csaw | Benchtop Machines | 5 | 01-24-2010 10:39 AM |
| My linistepper-a true GEM | student1616 | Open Source Controller Boards | 0 | 12-02-2008 10:59 AM |
| Linistepper | tante | Open Source Controller Boards | 7 | 12-19-2005 09:24 AM |
