| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
L297&l298n.jpgHi everybody. I have problem with wiring L297 - L298n. I did everything as in datasheet but i didn't get anything but a burning smell. Can someone please tell me what did i do wrong? I am trying to control bi-polar stepper motor by sending pulses from parallel port to L297 CW/CCW , half/full step ,reset , enable and Vref are connected to 5 volt Control to ground I am sending pulses to Clock from parallel port ( 3-3,5 volts ) Instead of 36 volts i am using 24 volts. I have 4 wired stepper motor and how can i connect them to L298n? Thanks |
RS1 and RS2 should be 0.5 Ohm resistors rated at least 3 Watts, preferably 5 Watts. Vref should NOT be connected to 5V! The voltage on the Vref pin sets the motor current per this formula: Stepper motor current (Amps) = Vref(volts) * 2. For example, to set the motor current to 1.0 Amps per phase, the voltage applied to Vref should be 0.5 Volts. The Vref voltage is usually derived by using a resistor divider from the 5V. Using a potentiometer in the resistor divider lets you adjust the Vref voltage. ED |
| Thanks. I check the the motor and it needs 6.4 ohm so i need Vref 3.2 volt. I build is again but this time without L298n and and i put 4 leds to the output of the L297. First i put them between every pin and ground ; but only 2 of them worked , also i changed the CW to high but the same and when i send pulses to clock they went off. Then i put pair for each output ; one pair between 4 and 6 numbered pin but opposite directions ; same same.... Why can it be? |
| Hello please download datasheet of L297 from http://www.st.com/stonline/books/pdf/docs/1334.pdf . Page 7 clearly mentions that VRef maximum voltage is 3.0Volts! Use the following formula VRef = Ohms of Sense Resitor * Motor Amps |
| Parallel L298N driver circuit help | Sidco7 | Stepper Motors and Drives | 12 | 02-28-2011 09:56 PM |
| L298N and L297 for stepper motor (unipolar) | same79 | General Electronics Discussion | 11 | 12-27-2010 11:01 AM |
| l297 | harshasunder | LinuxCNC (formerly EMC2) | 1 | 01-09-2010 01:09 PM |
| L297 for unipolar? | Mcgyver | Open Source Controller Boards | 31 | 12-10-2005 12:13 PM |
| L297 / L298n problems - whining motor! | bigal | Stepper Motors and Drives | 2 | 07-21-2005 04:32 AM |
