| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
| Hi oldpoppy70 , do you have one of the all in one 4 axis boards or a breakout board and 4 single axis drivers like this :- 5-AXIS (TB6560) CNC DRIVER BOARD 4 STEPPER MOTOR ROUTER | eBay depending on the meter you use your likely to get missleading reading if you measure the voltage across one of the motor windings ( the switching action of the current control will confuse cheap digital multimeters , not many people have expensive FLUKE test equipment) all you need to check is the supply voltage is within the safe limits for your driver (this can be several times the rated voltage for the motor!) put the ammeter in series with the positive motor supply to the board for a single motor without micro stepping you will then measure the total current for both coils with the all in one 4 axis board either dissable 3 axis or only connect the one motor John PS switch off before you disconnect or re-connect any of the wiring connecting or disconnecting any of the motor wiring with the power on will destroy the TB6560 IC Last edited by john_100; 07-31-2011 at 06:07 AM. Reason: add PS |
| Tags |
| instrumentation |
| 4 Axis TB6560 CNC Stepper Motor Driver Board + Cable | gabrivene | EBAY ADS | 2 | 01-15-2012 04:33 PM |
| eBay TB6560 Stepper Motor Driver Boards | Mad Professor | Stepper Motors and Drives | 128 | 08-31-2011 05:18 AM |
| Need Help!- TB6560 4 Axis CNC Motor Stepper Driver 3A 12-36V | vicsrc | Want To Buy...Need help! | 0 | 03-10-2011 10:57 AM |
| New Machine Build- How to wire stepper motors to tb6560 board | minga86 | General Electronics Discussion | 1 | 01-23-2011 01:22 PM |
| Need Help!- Stepper motor extremey hot - update: blew a tb6560 chip | _AR_ | Stepper Motors and Drives | 31 | 09-26-2010 01:32 AM |
