Go Back   CNCzone.com-The Largest Machinist Community on the net! > OpenSource CNC Design Center > Open Source Controller Boards
Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only)
  #61
Old 01-29-2012, 02:58 PM
Gold Member
Mariss Freimanis is on a distinguished road
lucas,
The dump circuit is unnecessary for recirculating mode standby. By definition the attack slope is steeper than the decay slope in this mode.
By the way H500's 06-12-2011, 09:43 AM post scope pictures show pronounced notches at the full-step locations (sin 0, 90, 180, etc.). This is due to an overly long reset pulse applied to the time-base counter. The reset pulse synchronizes the PWM to the step pulse frequency at the full-step rate. The purpose is to prevent beat frequencies between the step rate and the PWM frequency. An overly long reset duration introduces such artifacts.
Mariss
  #62   Ban this user!
Old 01-29-2012, 03:37 PM
lucas is on a distinguished road
Thanks very much for all the info wich you provided to allow us hobbiests build a decent drive.
I have a machine running with CPLD drive's from your tutorial and PCB design using your recommendations on PCB layout, it's working fine.
Will try to see what difference the change on the DUMP signal makes.
Originally Posted by Mariss Freimanis View Post
4) Circle the projected beam on the wall with a pencil.
Writing on the wall was forbidden by my ex-wife and I do forbid it to my grandchild also...
Edit:
I understand the synchronisation function between the step and PWM and I saw those notches also but seem to remember that there was a problem with the timebase counter, as far as I remember: The blanking period period doesn't start at the zero count. This didn't create problems with the original code but did when the code was modified for additional functions.
Have to check my notes but I think these notches were gone when I modified it.
Old 01-29-2012, 06:32 PM
Gold Member
lucas,
Is that your board? It's executed very neatly. I especially like how you compacted the high current section of the board layout. This shows thought about keeping high current traces short to minimize inductance.
I don't see your current sense resistors in the picture but I assume you know the significance of forming a good Kelvin connection ground.
For those that don't, the ground ends of the sense resistors have to be as close to each other as possible. That also is the only place you make your connection for all the low-level circuit ground returns. Think of your ground connections as being separated into two regions; noisy grounds (power section) and quiet grounds (low-level section). The meet at only one location, the ground ends of your current sense resistors.
Mariss
P.S. Like you, I'm also a grandpa. That means I'm old enough to reserve for myself rights I don't accord to my younger relatives; it's up to them to resolve the unfairness of the blatant hypocrisy.:-) Having said that, I do use a piece of paper on the wall but only because marks on the wall from repeated experiments confuse subsequent data-sets.
  #64   Ban this user!
Old 01-30-2012, 03:32 AM
Mariss,
thanks for the compliment.
I tried to respect the PCB design rules, this wasn't easy for a double sided board with all the different supply's and grounds.
They are SMD and are located on the solderside.
This was done to have a "star-style" ground on the ground pins of the power supply decoupling elco and cap keeping everything short and tidy.
There are also 2 seperate ground planes: power and signal.
Luc.
  #65   Ban this user!
Old 01-30-2012, 08:32 PM
H500 is on a distinguished road
Marriss,
Thanks for the tips. The lack of slope compensation was exactly what the problem was. If I remember correctly, Phil's code enabled the dump circuit only during standby.
I did not have time to troubleshoot the artifacts, but your suggestion is appreciated and makes sense. I will look at it after I'm done with the dsp board. The board works very well even with the artifact.
  #66   Ban this user!
Old 02-01-2012, 07:48 PM
nm156 is on a distinguished road
Okay, I'm not an EE, just a hobbyist but tried to figure out what Mariss was describing in his part III post. I found this, which is helpful (sorta) for us non-engineer folks.
This paper also mentions the use of applying harmonics to dampen resonance as he also mentioned in the part II post.
http://158.132.178.85/norbert/Papers/C070.pdf
Figure 8 is very interesting, showing a very linear corrected response, figure 3 gives an overview of how the system works.
  #67   Ban this user!
Old 02-03-2012, 07:31 PM
A lot of interesting information has been presented in the last few posts! If I understand correctly, both Marriss and the paper achieved vibration damping by superimposing higher order harmonics of the stepping frequency. That should be easy to enough try.
Old 02-04-2012, 12:36 AM
Gold Member
It's subject unto itself how to make an open loop step motor drive force a step motor to have good manners and behave itself. It means learning about every dark crook and cranny of a step motor's personality. There are many.
Mariss
  #69   Ban this user!
Old 02-04-2012, 06:32 PM
I just tried adding in the 3rd and 4th harmonics. It seems to reduce the vibration at the 10ipm resonance point, but it's hard to tell for sure. The vibration is quite low to begin with. I should probably use the laser pointer trick to optimize the linearity, but because the mill is working so well as it is, I'm not highly motivated. =)
  #70   Ban this user!
Old 03-29-2012, 08:14 PM
tivoidethuong is on a distinguished road
to h500, are you have test video clip?
thanks
  #71   Ban this user!
Old 03-30-2012, 05:08 PM
I will post one on the weekend.
  #72   Ban this user!
Old 03-31-2012, 05:58 PM
Here's a short clip of the driver in action on my sx3 mill. I don't know how to compress the video, so I'm keeping it short so my upload time is not too long.
Both motors are 280 oz in, 4 amp per phase and directly drive 5 tpi double nut ball screws. Both axes are set at 250 ipm. I think it's pretty good, considering that the weight of the cross slide is about 100lbs.
The cpld drive is on the y axis. The dsp drive is on the x. The latter has resonance damping, but it does not appear to make a difference on this setup. I am having a hard time deciding which drive I like better. I'll probably go with the dsp version since I find software easier than verilog when adding advanced features such as close loop control.
The system is temporarily running from a 34v 2 amp supply. The drivers have been tested up to 60v, 6amps with my nema 34 steppers. That will put out more than 160w per motor. I think that will be an overkill even for the Z axis, which needs to lift a 100lb head vertically.
6A 80V bipolar microstep drive, vote hope price beliefdrive Product Announcements & Manufacturer News 3 12-09-2009 05:46 PM
Does bipolar wiring of a unipolar motor create more torque if you microstep? christ371 Xylotex 0 11-18-2009 02:37 PM
Bipolar Microstep 48 volt 5Amp /phase, 4 axis board kreutz Stepper Motors and Drives 571 08-17-2009 04:49 PM
NEW Microstep Drive Module jafgraphics Product Announcements & Manufacturer News 0 02-02-2007 12:36 PM
