| Open Source Controller Boards Discussion for Open Source CNC type Controller Boards and other related items. (for personal use only) |
HI! I'm new here, and I need some help... I have a lathe, and I want to cnc it..., i bought 3 siemens 1fs5044 servos... those are 3 phase AC servos, 1.15Nm, 3000rpm, 200 volts 3/3.5amps. they have hall efect encoders (3 hall sensors as I saw...) I have no more data about them, just that I mentioned uphere. i need some hel with the servo drives, because some guy told me I have to use siemens drivers only, I was thinking on a DIY ACservo drive but I can't find anything like that on the Inet. do you have some idea what can i do with this 3 things here??¡ finally... sorry about my terrible english, I have no too much practice really... |
| It depends on what system you intend integrating them into, and what type of servo control the intended controller uses, i.e. step/dir or ±10vdc analogue control and whether you need an intelligent drive with Dsp logic where the loop is closed back to the drive rather than the CNC control. For e.g. I use ±10vdc analogue non-intelligent drives and the servo loop is closed back to the CNC control, the drives examples are ADVANCED Motion Controls - servo drives and motor drivers with Advanced Motion Control BLDC motors with hall effect commutation are relatively easy to find drives for. Al.
| I think this ones are BLAC, not DC... that's what I'm afraid about. I don't have the pc interface yet, i was thinking buy a pci card from GALIL or something like that... or a LPT breakout board for cheaper begining... I haver never done anything like this before, so I know nothing about what plan to go for! |
| Even if they are AC sinusoidal and just use the Hall effect for start up, you should be able to use them with a regular BLDC drive in BLDC mode, although BLAC are superior. Al.
| well... here I am again... I have in my hands a toyoda ac brushless servo drive... it looks like if I fit a 8192p/r encoder it will work, but i need a software called MOwin5 to connect it to my notebook and set it up... somebody got it? |
| Using Siemens | erdinct | Siemens Sinumerik CNC controls | 4 | 03-23-2011 09:34 AM |
| Siemens 810 T | promehanik | EMCO Lathe | 1 | 05-24-2010 04:50 AM |
| Siemens NX Cam | kurt5 | General CNC (Mill and Lathe) Control Software (NC) | 0 | 06-29-2009 02:33 PM |
| Siemens NX 6 | malcolmx | Spanish CNCzone | 2 | 03-23-2009 04:35 PM |
| Siemens 850 | Thunder | G-Code Programing | 0 | 09-17-2007 03:10 PM |
