Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: linistepper over heating need help
    Oct 2010
    I just finished building my new 4 axis linisteppper with the V2b PCB's all looks good but when I tried to run the first motor test the 5 watt resisters got red hot when the motor clamped on (I mean RED). I guess I'm ask'en what could I be doing wrong? I have noticed when I hook up the BOB PCB all the power transistors show to be grounded also the 5watt resisters are grounded is it me or is this not right.when the BOB is detached all is well. where do I need to start?
    Thanks Kevin
    Registered James Newton's Avatar
    May 2005
    Check the part number on the small transistors... some kits were sent with the wrong ones, but a follow up email "recall" was sent out to everyone asking them to check and offering free replacements and "goodies" if we got it wrong.
    If that isn't it, what voltage is your power supply and what are the specs on the motor? Especially the coil resistance.
    Oct 2010
    Thanks James everything looks good with the kit. my problem is with the size of my motors I thank I'm thing to run an old SLO-SYN 1.7v 4.7a. 150 oz I was just reading about how to tune the linistepper and it comes up with a .21237 ohm resister how do I do this. what would the wattage be.
    <'m running a 24 volt power supply 400 watt>
    May 2005
    You can't run a 1.7 volt almost 5 amp motor from a 24 volt supply with a Linistepper. Drop to 12 volts at /most/ 9 volts would be better. If you put in smaller resistors (in an attempt to tune for the 4.7amps) they will just fry quicker. The Linstepper is rated for 3 amps at MOST. Recommended current is 1 to 2 amps. The kit comes with one set of two 1 ohm resistors which will supply 1 amp. There are holes to solder in a second set of 1 ohm resistors which will result in a 0.5 ohms and will provide 2 amps.
    But again, they are always going to fry if you try to run that motor with that power supply. If you want to run a 24 volt supply, get a motor that is rated at around 12 volts. There are some good motors listed here:
    Good Stepper Motors for the Linistepper
    which are a better fit. Try for some with higher volts and lower amps.
    Oct 2010
    Thanks for the help !!!
    Feb 2009
    Hi, sorry for reopening the thread, but I have the exact same problem: on one of my driver boards the sense resistors (0.75ohm, 5W) are getting hot quickly while the motor is not turning.
    The same motor (2A) and same set of TIP122s work with the other boards (they're connected with wires/molex). I've checked for visible defects but there's nothing obvious. Do you guys know what should be the next step of troubleshooting?
    Thanks a lot,
    Peter
    May 2005
    Check the part number of the small transistors.
    Feb 2009
    Hi James, all transistors are BC337.
    May 2005
    Does the motor ever turn?
    Feb 2009
    No it doesn't move at all
    May 2005
    Check the PIC. Power, gnd, clock. Etc
    Feb 2009
    I reprogrammed the PIC. Also GND and power is ok on pin 5 and 14. not sure how to check the clock.. I guess the next step is replacing the small transistors?
  • Page 1 of 3 123 LastLast
    1. Linistepper new board
      By salvado in forum Open Source Controller Boards
      Last Post: 03-06-2012, 06:12 PM
    2. Linistepper in C
      By hazimin in forum PIC Programing / Design
      Last Post: 01-23-2011, 09:34 PM
    3. FYI Linistepper Experience
      By flyboy1015 in forum DIY CNC Router Table Machines
      Last Post: 11-12-2008, 04:38 PM
    4. 'Lil Linistepper Lathe
      By epineh in forum Mini Lathe
      Last Post: 02-24-2008, 09:03 AM
    5. Linistepper
      By tante in forum Open Source Controller Boards
      Last Post: 12-19-2005, 10:24 AM
